Old Nov 11, 2009, 04:33 PM
norstaroption is offline
Find More Posts by norstaroption
norstaroption's Avatar
Pacifica, CA USA
Joined May 2009
Stock Zagi 400x and 3s Lipo
I just purchased a 5 year old Zagi 400 x with stock zagi motor and esc. It came with 9.6 nicad batteries. I'm wondering if I can use my 3s zippy 2200 lipo without damaging the esc and motor.
norstaroption is offline Find More Posts by norstaroption
Old Nov 11, 2009, 06:59 PM
Atom1025 is offline
Find More Posts by Atom1025
Fly me to the moon...
Atom1025's Avatar
Sacramento
Joined Jun 2005
Cant say for sure on the esc but the motor will prolly sizzle on 3s.
Brushless is so cheap, save the hastle of crashing with an underpowered wing and get yourself something solid.
Atom1025 is offline Find More Posts by Atom1025
Old Nov 12, 2009, 10:06 AM
Pacifica, CA USA
Joined May 2009
I have tons of Energizer Rechargable batteries, can I use those?
Old Nov 12, 2009, 10:53 AM
Atom1025 is offline
Atom1025's Avatar
Sacramento
Joined Jun 2005
First of all lets discuss your goal with this.
Do you want a reliable flier? ie: do you have funds to invest?
Or are you just trying to get this airborne on the cheap for some giggles?
You can use any battery technology assuming it provides a "usable" voltage and assuming it will properly cg the ship.
If you do your research you can learn what others have found out very quickly, the stock setup just wont cut it.....
Old Nov 12, 2009, 01:41 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Just grab a cheap ebay esc itll do until you decide which way you want to go with the wing.
scousethief is offline Find More Posts by scousethief
Old Nov 12, 2009, 01:55 PM
Pacifica, CA USA
Joined May 2009
Well, I flew this wing today and it is definitely a beginners electric wing. Like what Atom said it doesnt have enough power to do anything. I can't do loop and very hard to fly inverted.
Thanks.
Old Nov 12, 2009, 08:51 PM
Ebolavoodoo is offline
Find More Posts by Ebolavoodoo
Ebolavoodoo's Avatar
United States, CA, El Cerrito
Joined Jan 2007
I had a Stryker B with a brushed motor that used crap NiCad batteries. I put a 3s lipo in it. So much better. Of course, motor lasted 1/3 as long. But worth seeing it move much faster and stronger.
As others have said, upgrade to brushless. $30 can you a motor and esc online.
Jerry
Ebolavoodoo is offline Find More Posts by Ebolavoodoo
Old Nov 13, 2009, 01:30 PM
Rota is offline
Find More Posts by Rota
Rota's Avatar
Mesa, AZ
Joined Jul 2008
Check out www.rctimer.com for a cheap brushless motor and ESC and you'll be very satisfied with that plane.
Rota is offline Find More Posts by Rota
Old Nov 13, 2009, 02:00 PM
Pacifica, CA USA
Joined May 2009
Wow, very good prices. Where is that company located? I'll do more research, need to know which motor will perfectly fit on the motor tray.
Thanks.
Old Nov 15, 2009, 06:44 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Any 28mm inrunner (see www.lightflightrc.com) should fit that tray if you trust a ziptie to hold a 200W-300W..... ++++ motor.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 17, 2009, 09:14 AM
B.Welwood is offline
Find More Posts by B.Welwood
Always in the Glue
B.Welwood's Avatar
Edmonton, Alberta
Joined Oct 2003
You should also consider strengthening the airframe when upgrading bthe power system on your Zagi.
http://www.rcgroups.com/forums/showp...18&postcount=4
B.Welwood is offline Find More Posts by B.Welwood
Old Nov 18, 2009, 12:25 PM
Sethorus is offline
Find More Posts by Sethorus
Sethorus's Avatar
St. Louis
Joined Aug 2007
Yes you will fry the stock ESC with that setup. I fried mine using the stock setup and 3S 2350 Rhinos after about 3 flights, rolled over and went in hard, actually bent my battery. I upgraded to a 30 ESC, from an old wattage kit, and haven't had any problems since.
Sethorus is offline Find More Posts by Sethorus
Old Nov 18, 2009, 11:21 PM
rwp is offline
rwp
Find More Posts by rwp
rwp
rwp
rwp's Avatar
Joined Nov 2003
Originally Posted by B.Welwood View Post
You should also consider strengthening the airframe when upgrading the power system on your Zagi.
I agree.
rwp is offline Find More Posts by rwp
Old Nov 18, 2009, 11:30 PM
Pacifica, CA USA
Joined May 2009
I've running mine with my Zippy 3S 2200mah with no problems so far. Ofcourse, I don't full throttle all the time.
Zagi 400X (Crappy stock ESC replaced with ESC without brake, is this OK?) flipnidaho Foamies (Kits) 7 Mar 09, 2003 09:23 AM
Stock Zagi 400x and Li-PO ? hemna Batteries and Chargers 0 Feb 07, 2003 02:06 PM
Zagi 400x Stock Batteries sbuechler66 Foamies (Kits) 12 Feb 25, 2002 12:03 PM
Outside loops with Zagi 400X stock setup? 177ichael Foamies (Kits) 5 Aug 03, 2001 03:40 PM
inverted flight with Zagi 400X stock setup? 177ichael Electric Plane Talk 10 Jun 25, 2001 08:18 PM
