Old Aug 20, 2009, 01:28 PM
Stuey is offline
Find More Posts by Stuey
Aylesbury,UK
Joined Apr 2000
Delta-V 15 fan problem
Hi, I have fitted a Delta V 15 fan and the Eflite 3600kv motor to my KC F-18 kit. I have taken some measurements on the intended 4S 2250 30C Loong Max pack, which seem wrong. After the first peak of the freshly charged pack had gone, I was getting 850watts at 56 amps!! I am using a Pentium 60A controller on low timing. This is a lot more than I was expecting, and more than I have seen advertised on the site I bought it from.
I then tried it on a 3S pack, and got 400watts at 37 amps. This is also higher than I would expect, I thought it might be nearer 30 amps.
This was measured on an Astroflight watt meter. I am wondering what I can do about this, would I be able to use the transmitter end point adjustment to limit the speed controller from reaching full power? As much as 850watts might be fun, the motor wires were getting a bit warm, and the motor is supposed to be 750watts max. Help!!!!!
Stuey is offline Find More Posts by Stuey
Old Aug 20, 2009, 02:04 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
750 watts is the rated power not installed in a plane.When You add the ducting it loads the fan and raises the amp draw..I have measured as high as 900 watts installed in a the eflite Hawk.. your numbers look pretty much as what you should get..you should be fine!
Old Aug 20, 2009, 02:47 PM
Stuey is offline
Aylesbury,UK
Joined Apr 2000
Ok thanks for that. The duct is quite open and free flowing compared to what I have seen of the Hawk, maybe thats why it is under the 900watts you got. Still seems a bit high, I was aiming for something around 600-650watts. I may take the fan out and try it like that out of curiosity.
Old Aug 20, 2009, 04:21 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
I dont think you will see 650 unless you use a diffrent motor..the KV is going to make the numbers you are allready getting. I say run what you have..as long as there is good airflow in the fuse for cooling you should be fine
Old Aug 21, 2009, 01:14 AM
Stuey is offline
Aylesbury,UK
Joined Apr 2000
Thanks Turbonut. I have looked at a few threads regarding using the end point to restrict the throttle movement and reducing the overall output, some say ok and others no. I dont fly any of my EDF models at full power all of the time, so I would think it will work ok. I would like some more guidance from you guys out there please
Old Aug 21, 2009, 06:56 AM
juliant is offline
Find More Posts by juliant
Julian T
Fleet, UK
Joined Jun 2005
Generally not considered a good idea. It depends to a degree on the controller, some are much more efficient at part throttle than others, but fwiw I would enjoy some full throttle bursts and between them some lower throttle cooling down periods. In the air you should be ok with that regime.
Personally I do prefer to use a setup I can fly full throttle for 3 minutes flat out as the lower throttle bits seem rather tame after the bursts! If you are in doubt why not fly with short bursts and see how your temps are after the flight. If ok, try longer bursts and so on. That has worked for me when I have been concerned about a particular setup.
Julian
juliant is offline Find More Posts by juliant
Old Aug 21, 2009, 02:50 PM
St. Martin is online now
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
56A is cutting it close to the 60A rating of your controller. Some controllers are under-rated. But all controllers are less efficient at reduced power. This causing higher operating temps. Then to throw anothe wrench in the works..if you batt/controller leads are long, you could get a voltage spike. When going from reduced power to full.
So, if you run at reduced power, to conserve batt time or batt temp, the controller gets hot. Try for a 10A extra capacity in the controller, minimum. And on 4s, you may need a seperate BEC or Rx pack.
Fuzz
St. Martin is online now Find More Posts by St. Martin
Old Aug 21, 2009, 03:39 PM
Stuey is offline
Aylesbury,UK
Joined Apr 2000
I have decided to try the model tomorrow (weather permitting) on a 3 cell pack. This is around 400watts, which will be about 200w/lb. I tried it at full throttle with the nose vertical to see how it felt, and it could just about hold its own weight. I am thinking of trying a wemotec minifan rotor instead, if I can find out the comparitive amp draw on the same wind motor. Hoping it will pull a bit less.
The Eflite package is usually supplied with an Eflite 60A controller, which could be as marginal as my Pentium 60A (on 4S). As far as the bec goes, it is a switching type in the Pentium, which I believe is more efficient than a linear version.
Old Aug 21, 2009, 04:12 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Nothing wrong with 200w/lb. Good luck!
Fuzz
Old Aug 21, 2009, 05:04 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
As long as you have good cooling air flow I dont think you will have a problem..just dont run WOT for a long time..but on 3s it can fly a whole pack WOT
Old Aug 24, 2009, 02:26 AM
Stuey is offline
Aylesbury,UK
Joined Apr 2000
Flew the F-18 on saturday, apart from being a bit out of trim it flew really well, not too bad on 3S either. Glad to get it out of the way, put quite a few hours in building it!! Would like to get it up to about 650-700 watts, which should be just about right.
Help! Delta V-15 annihil8ted Foamy EDFs 15 Jul 15, 2009 06:06 PM
Help! Eflite Delta V-15 annihil8ted Foamies (Scratchbuilt) 0 Jul 08, 2009 09:26 PM
For Sale E-flite Delta-V 15 EDF unit and BL15 DF Brushless Motor jimx5000 Aircraft - Electric - Jets (FS/W) 4 Jun 01, 2009 07:54 PM
Sold Two NIB E-Flite Delta-V 15 70mm Fans lavochkin Aircraft - Electric - Jets (FS/W) 5 Mar 27, 2009 11:48 AM
Discussion This is the new E-flite Delta-V 15 70mm fan... lavochkin Electric Ducted Fan Jet Talk 10 Oct 17, 2008 09:25 PM
