Old Nov 29, 2012, 11:48 AM
United States, TX, Coppell
Joined Feb 2011
Turnigy D or SK3 series?
I'm having a heck of a time deciding between these 2 motors:
Turnigy Aerodrive SK3 - 3542-800kv
Turnigy D3548/6 790KV
This is for the new 48" Skywing/Wattaplane full fuse Edge 540T (the scale looking one).
Does anybody have experience with these? How would they compare to an Omega 130g, or the Hengli motor?
jtaylor996 is offline Find More Posts by jtaylor996
Old Nov 29, 2012, 11:54 AM
VOLTS > AMPS
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
I used a 35-42 in an exp 48" on 4s with a 12x6 prop for months. I would go with that one. Y bearings went out and I sent it to ken at sub sonic motors to fix.
stgdz is offline Find More Posts by stgdz
Old Nov 29, 2012, 09:25 PM
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
I have been using the other version (wires below the output shaft)
http://www.hobbyking.com/hobbyking/s..._AXi_2826.html
of the 3548/790kv motors for over three years. They are actually available here...
http://www.leaderhobby.com/product.asp?ID=9394001226125
I have one in an Edge 540 (50") ARF full fuse running 4 cell that pulls 36A (initial charge voltage) with 14x7 prop. I have only flown it a few times with this combination as I fly mostly gliders now. It is limited in pitch speed (~47mph) which is fine by me as it is a somewhat fragile 50" plane. This combination gives it roughly 90oz of static thrust for 51oz plane (at least that is what is in my notes - the thrust is from Motocalc).
I also have used 4 of these at 3 and 4 Cell pulling between 30A and 50A but in gliders which are limited to 30 Seconds of run time or less. I also have switched to some of the 1100KV ones which I find to be just a little better for my gliders such that I get a little better pitch speed for the props I use at the 3 cell level.
My experience is that at least for these specific motors, they work "fine" and will run at 35A to 40A with 4Cell. I have run these with peaks to 50A but motor does get hot and I don't recommend that for any appreciable duration.
I caution you to look inside to make sure no wires are loose from the windings that could get caught and force a short. I did have one that I caught when I first bought these but all recent ones have been perfectly fine (I probably have 10 now of these motors - 800 and 1100 KV combined). The others have been just fine and I now glue down the wires when I take them apart (such as to reverse orientation for mounting).
The bearings must be handled appropriately - don't let the housing slam into them for example when taking them apart as it likely will damage them. With my flying, I suspect I will never wear them out but hey at under $20 - whom cares.
One last thing - bear in mind that efficiency on these motors drop as you pull more current - so i suggest the 3548 over the 3542 just for that reason if you can handle the weight.
Scott
ScottSails is offline Find More Posts by ScottSails
For Sale Turnigy Helidrive SK3 Competition Series 4 NIB blawren Aircraft - Electric - Helis (FS/W) 0 Nov 21, 2012 10:51 AM
Wanted AerodriveXp 25 SK3 Series 35-42 1250Kv or equivalent gregory.da Aircraft - Electric - Power Systems (FS/W) 0 Jul 15, 2012 11:53 AM
Discussion Turnigy SK3 3548- 1050kv or NTM prop drive 35-48A 1100kv rcalldaylong Power Systems 7 Jul 11, 2012 11:53 PM
Mini-Review New Turnigy Sk3 Series Outrunners, Turnigy's "High end" Outrunner daign Multirotor Talk 20 Apr 26, 2012 04:28 PM
Discussion KDA (hacker style) or Turnigy sk3? 7ender Power Systems 6 Mar 13, 2012 08:28 PM
