I got the majority of the water tank built, still have to install the servos and hookup the linkages and then test for leaks. I really like the way that Martin designed the tank. It's operation is just about identical to the way the full size works.
Been a while since I last worked on the CL-415, I had a Cub that I wanted to get some floats built for that took priority but now that that's taken care of I'm back to the CL-415.
With the water tank finished up the next step, in assembly of the fuselage, is the main gear. Martin did another great job in engineering on the retracts. They look and operate just like the full size aircraft. With that being said it also means that you don't just drop in an assembled unit and bolt it in place, you have to build them from the ground up. The gear, much like the water tank, are almost a kit with in the kit. It took me 2 days to get them built, installed and working properly. Since the fuselage parts are interlocking I took advantage of this feature and dry fit everything , using clamps to hold it together, and tested the gear to make sure everything was as it was supposed to be and working good before gluing it all together. It really worked out good this way as I was able to take it apart to tweak ta few things not to mention a couple of parts that I didn't have installed properly on the first attempt.
HM, Thats gonna be nice!
![]() Have you seen this hydraulic gear conversion? http://www.hobbyking.com/hobbyking/s...dProduct=14054
| Thread Tools | |
| Discussion HobbyKing CL-415 Canadair 1390mm wingspan Foam Kit | JGuilty13 | Waterplanes | 1352 | May 14, 2013 07:31 PM |
| For Sale Canadair CL-415 80.7'' for $239 | richyan | Aircraft - Fuel - Airplanes (FS/W) | 0 | May 25, 2011 01:26 PM |
| For Sale MR Aerodesign Canadair CL-415 Kit Complete | Rudderman98 | Aircraft - Electric - Airplanes (FS/W) | 0 | May 19, 2011 11:05 PM |
| Help! Beldone Canadair CL-415 Kit Instructions | dmontbans | Scale Electric Planes | 0 | May 19, 2011 02:44 PM |
