Old Feb 08, 2013, 12:28 PM
Philippines, NCR, Quezon City
Joined Apr 2012
Good filler for EPP foam
What material do you use as filler on EPP foam? I want to repaint my foamy F35 with better looking paint job. But I'm also sanding it first till i see white.
DYORD is offline Find More Posts by DYORD
Old Feb 09, 2013, 10:13 AM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
You could try the light weight spackle. It's in the container that feels empty when you pick it up. It sands easy and can be thinned with water for easy application. I've even thinned it enough to spray it on with an automotive touch up gun.
ken
kenh3497 is offline Find More Posts by kenh3497
Old Feb 09, 2013, 10:52 AM
Joined Apr 2012
ken
Thanks!
Can this easily be found in bookstoreS?
Old Feb 09, 2013, 06:14 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Hardware stores or Paint stores
ACE hardware
hoppy is offline Find More Posts by hoppy
Old Feb 12, 2013, 08:46 AM
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Just curious. Wouldn't the spackle be brittle, and flake off when the model is under stress ?
Spackle works well for me, over wood, but under a covering of some sort, ie glass cloth or Monokote. I would worry about it if was just covered in paint.
TomCrump is offline Find More Posts by TomCrump
Old Feb 12, 2013, 09:01 PM
yel914's Avatar
SLC, Ut
Joined Apr 2010
I use that same stuff with good results. I think it's OK if you put it on parts of the structure that don't flex much. When it's dry, I sand smooth and follow it up with a coat of PolyC that sort of soaks into the spackle to help strenghten it.
yel914 is offline Find More Posts by yel914
Discussion Needing a good foam filler bmrmiller 3D Foamies 5 Jan 01, 2012 09:06 AM
Discussion Does anybody know a good filler for foam benjo Foamy EDFs 21 Aug 22, 2010 12:06 PM
Help! good foam spray filler Kluwe Foamies (Scratchbuilt) 5 Apr 14, 2009 11:43 PM
EPP Foam Filler copertop Foamies (Kits) 4 Oct 29, 2004 07:23 PM
