Old Jan 03, 2013, 02:15 AM
vtol fan
nadine's Avatar
Joined Jul 2009
Question
Lipo charger
Hi guys..
I need to buy one small usb charger for one single lipo,rate charge min.10mah and max.50mah,it will be ok.
I have I MAX but the minimum charge current is 100 mah.
Somebody know where i could find?
Cheers..
nadine is offline Find More Posts by nadine
Old Jan 03, 2013, 07:17 AM
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
http://www.didel.com/07charger/Bicha2.pdf sounds like just what you need.
Petefoss is online now Find More Posts by Petefoss
Old Jan 03, 2013, 08:48 AM
vtol fan
nadine's Avatar
Joined Jul 2009
Hi Pete.
I found this at sparkfun,what do you think!?
https://www.sparkfun.com/products/10401
Cheers
Old Jan 03, 2013, 11:40 AM
Petefoss's Avatar
Joined Aug 1999
Looks like it's a fixed charge rate of 0.5 amps. Unless you modify it. The Diedel has dip switches to change the current.
Old Jan 03, 2013, 12:12 PM
jjifar's Avatar
South Korea, Chungcheongbuk-do, Cheongju-si
Joined Jun 2009
Lithium polymer battery 3 magnification (3C) can be charged.
In other words, 10mAh battery charging is possible. 30mA
Will be the following ways: If you need to charge now.
1) Prepare a large discharge capacity battery.
2) Prepare a tester that can measure the current.
3) charger that you have to 1) of the battery charge.
4) Current is measured.
5) are connected as shown below.
Charger(+) <----> Variable Resistance(50k ohm?) <---> tester <----> Batteries(+)
Charger(-) <--------------------------------------------------------> Batteries(-)
6) 30mA by turning the variable resistor is adjusted to flow.
7) Replace the battery with 10mAh charge.
I did not try the experiment. ^ ^;
jjifar is offline Find More Posts by jjifar
Old Jan 03, 2013, 02:45 PM
vtol fan
nadine's Avatar
Joined Jul 2009
jjifar,thanks,for you tips...looks interesting,but too complicated for mee
I think i will go with,something,like sparkfun and i will try to recalculate the resistor
for a few charhging rates,10-20-30-40-50 mah and so on till 100 mah.And with help by a micro switches to select the correct rate needed..Cheers
Old Jan 03, 2013, 03:34 PM
jjifar's Avatar
Joined Jun 2009
10mAh battery to charge I do not think we'll need to charge to 10mA.
10 ~ 50mAh battery being charged three times to 30 ~ 150mA If you thought it was safe.
Look, see below MCP73831 charger.
http://www.rcgroups.com/forums/showt...light=mcp73831
Sold GT POWER X-CHARGER C6 6S LiPO Charger NEW Mikemynameis Aircraft - Electric - Batteries & Chargers (FS/W) 2 May 23, 2012 04:27 PM
Sold E-flite Battery Charger 3s 11.1V Lipo Charger Price Reduced fluxcapacitor121 Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 23, 2012 12:28 AM
Sold Eflite Battery Charger 3s 11.1V Lipo Charger fluxcapacitor121 Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 14, 2012 06:32 PM
Sold For Sale JR 6102 with Case RX and charger plus LIPO charger crazyskypilot Aircraft - General - Radio Equipment (FS/W) 1 May 06, 2012 08:59 PM
Sold Thunder Power Charger TP-425 lipo Charger smokeytbear Aircraft - Electric - Airplanes (FS/W) 6 Feb 29, 2012 12:41 AM
