Old Nov 20, 2001, 09:10 PM
USA, PA, New Hope
Joined Nov 2001
Another Mytus assembly question
I got the hint that my canopy assembly problem may be bogus. Seems like nobody is using the inner canopy because the battery has to be moved way up to balance and it won't fit.
My next step was to mount the motor and see where I balance. Side thrust/downthrust. The manual says 2 degrees down and right but this seems to be for a direct drive. I bought the reco 2.3:1 planetary from Hobby Lobby and the stock speed 600 and will use a bigger prop. Some thread that I read a while ago mentioned 4 degrees right and 4 degrees down for a geared setup because of the bigger prop. I can't find the thread again to check the specifics. Anyone got good results?
Vito is offline Find More Posts by Vito
Old Nov 20, 2001, 10:31 PM
Dale Lindsay
Mt Airy, Maryland, United States
Joined Sep 2001
I'm using a MM with a 2.8:1 GB - a 12x8 prop. I added about 1/8" right and down to the firewall. I get pretty level power-on flights. Also with your set up the 600 might add a little nose weight so you might not have to come so far forward with the battery.
Mount it all up without permanently gluing anything in and see how it balances out. That way you can crack the stuff loose and move it around if you need to.
DaleM is offline Find More Posts by DaleM
Old Nov 20, 2001, 11:15 PM
Dale Lindsay
Joined Sep 2001
Discussion Another RC10T4 assembly question Twinboom Off-road Cars 4 Oct 31, 2006 12:23 AM
another intake design question Jensst Electric Ducted Fan Jet Talk 15 Oct 18, 2001 10:20 AM
Graupner Prop assembly question cold boy Beginner Training Area (Aircraft-Electric) 3 Jul 11, 2001 01:53 AM
another t-52 question hoppy Foamies (Kits) 4 May 16, 2001 01:22 AM
Another Simple 400 question Nose_Dive High Performance 5 Apr 26, 2001 12:41 AM
