Old Jul 28, 2004, 08:54 PM
LNL
Oak Harbor, WA
Joined May 2001
Partenavia Motor System Help!!!!
My Partenavia had a successful maiden. Plane is stock with Graupner
480 Motors, APC-E 6 X 4 Props, Jeti ESC, 8 cell RC2400 Pack, Anderson
Power Pole Connectors used thru out. All Connections tight.
2nd flight left motor started missing and went out. I replaced it with
a new Graupner 480 Motor.
3rd flight left motor worked fine, but right motor started missing and
stopped. When I hit the prop, it would start for a while, then stop.
WHAT IS WRONG? Help LNL
LNL is offline Find More Posts by LNL
Old Jul 28, 2004, 09:54 PM
small electrics r BIG FUN
Iowa
Joined Aug 2000
Which Graupner 480's ? My stock Partenavia came with 480's which are really just long can 7.2v 400's. Are your motors in series or parallel ? What size is the Jeti esc ? Even with the 7.2v motors and 6.5 x4 props, I was pulling 26 amps with 8 cells RC-1200 (same as CP-1300). Plane flies great, very scale with stock power set.
Al P is offline Find More Posts by Al P
Old Jul 28, 2004, 10:22 PM
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
Did you break in your motors ? I torched my graupner 480 by running it hard without proper break in . These motors seem to be sensative that way .
jmolwitz is offline Find More Posts by jmolwitz
Old Jul 28, 2004, 11:36 PM
LNL
Oak Harbor, WA
Joined May 2001
Partenavia Help
I did not break in the motors. The motors are Graupner 480's, 7.2 volts.
The Jeti ESC is the 350, which will handle 12 nicads. LNL
Old Jul 29, 2004, 12:31 AM
Australia
Joined Mar 2004
they might be getting too hot?
Philpops is offline Find More Posts by Philpops
Discussion Help in wiring Dual Brushless Motor System - Crash_Clark Power Systems 17 Feb 10, 2007 08:46 PM
Yippee! Motor system help please! Sceadu Flyer Power Systems 1 Nov 27, 2005 03:02 AM
Need Help on Electric Motor System joe1 Power Systems 10 Dec 27, 2004 10:20 PM
Need Help Selecting Motor System joe1 Electric Sailplanes 1 Dec 23, 2004 08:26 AM
problem with motor system...help! sdcfish Power Systems 7 Feb 02, 2003 01:14 PM
