Old Jun 20, 2004, 05:21 AM
Goodychrischild's Avatar
Bristol, UK
Joined Oct 2002
Finishing up my RNAF Hellcat
My Molt Models Hellcat had its maiden a couple of weeks ago in its bare, unfinished state and flew really well on the standard set-up (IPS) and a 700 mah Etech. Therefore it has been my goal to get her dressed up as one of the Britsh F6F's and here is my progress.
The airframe was mainly covered with Doculam (that I never used on my Swichback kit) but I did have a few wrinkle problems and resorted to solite in a few areas. The whole plane was cleaned with some vinegar to degrease and then Prymol etch primer was used to give a good base for the paint to stick.
Goodychrischild is offline Find More Posts by Goodychrischild
Old Jun 20, 2004, 05:25 AM
Bristol, UK
Joined Oct 2002
I mad a couple of minor changes along the way.
1. I found a that I snapped a few of the stringers on the lower front edge (my balsa did seem very light and fragile in this area) when making less than perfect belly landings, so I decided to fill som of this area in to add some strength.
2. I wanted the option of flying with or without the landing gear and so I have added some spruce bearers either side of the gear mount points that can take some small screw on plates to secure the gear.
Old Jun 20, 2004, 05:35 AM
Bristol, UK
Joined Oct 2002
The underside was sprayed with Tamiya XF21 - Sky
Old Jun 20, 2004, 05:40 AM
Bristol, UK
Joined Oct 2002
Then a bit of 'Fun' with the cockpit,
I did get a vac formed man with the kit, but I felt he was a little on the large size for this plane so I knocked one up from some foam packing material and masking tape plus spackle (he's not meant to be true scale, just a representation!). He doesn't even register on my scales! The instruments were just printed out and stuck on and a seat was added from scrap balsa.
Old Jun 20, 2004, 05:45 AM
Bristol, UK
Joined Oct 2002
Then the canopy can be stuck on (used contact advesive) and masked up ready to spray the camoflage.
Old Jun 20, 2004, 05:54 AM
Bristol, UK
Joined Oct 2002
So on with som more Tamiya acrylic, XF22 RLM Grey and XF24 Dark Grey.
Old Jun 20, 2004, 05:55 AM
Bristol, UK
Joined Oct 2002
Whoops, no pics, lets try again
Old Jun 20, 2004, 05:58 AM
Bristol, UK
Joined Oct 2002
Here's one more shot for now, of the little chap in his office, plus a picture of what I'm working from (ie what I hope it gets to look like! )
Chris
Old Jun 20, 2004, 06:01 AM
Bristol, UK
Joined Oct 2002
Sorry here's one of the pics I'm working from:
Old Jun 20, 2004, 08:10 AM
Centreville,VA,USA
Joined Apr 2001
Excellent! Love your proposed sceme...Didn't know about your pilot though... But seeing it in the painted plane he looks ok just a little war weary
Pete
mtflyr is offline Find More Posts by mtflyr
Old Jun 21, 2004, 08:40 AM
Bristol, UK
Joined Oct 2002
Thanks mtrflyr, I wasn't too sure a bout the pilot at first either, but the canopy is not very clear so I would have been even more upset if I could'nt see my efforts having spent ages on an exact scale pilot! I think he look fine through the 'frosted' glass! Much better than without one at all.
Got the white invasion stripes sprayed today and I've also done some more painting on the nose, I'll post some more pics later if you like?
Chris
Old Jun 21, 2004, 11:13 AM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Chris
Hi Chris. Of course!
Steve
St. Martin is online now Find More Posts by St. Martin
Old Jun 21, 2004, 09:24 PM
helimatt's Avatar
NJ
Joined Feb 2002
Nice work Chris - keep the picture coming!
Mine is coming along too. I will be posting more shortly.
- Matt
helimatt is offline Find More Posts by helimatt
Old Jun 22, 2004, 04:47 AM
Bristol, UK
Joined Oct 2002
Thanks Guys,
So heres a little more progress as mentioned.
The nose ring was painted matt red enamel and also note that the intake fins have been added as these are not in the vac forming. The engine was painted with 'burnt steel' and Imay dry brush a little silver over later.
The white stripes have been sprayed on, again using Tamiya acrylics, one note here is, don't use biro to mark out and then try and overpaint with acrylic (don't ask me how I know!). I had to remove the biro from these areas and re-do in pencil after re-prymol'ing (prymol is also a good acrylic stripper!!! ).
Old Jun 22, 2004, 04:52 AM
Bristol, UK
Joined Oct 2002
Here's a shot with my 4 year old holding it.
next job is to do the black stripes, not sure wether to be lazy and try brushing them on as I get tired of masking, also some flakes of paint do tend to lift if you're not really careful even though I'm using low-tack stencil masking.
Chris
How to set up my first plane? dshuen Parkflyers 9 Nov 05, 2001 05:05 PM
advice setting up my E-glider JoeR Electric Sailplanes 3 Oct 09, 2001 10:19 AM
Stiffening up my Zagi - Its Getting Soggy! AndrewK Foamies (Kits) 11 Jul 21, 2001 02:19 AM
Setting up my second Adrenalin, some questions... Erik Johansson High Performance 0 Jul 01, 2001 05:45 PM
Cant make up my mind ? exowatt Electric Ducted Fan Jet Talk 1 Apr 28, 2001 08:57 PM
