Old Feb 22, 2015, 01:00 PM
Portugal, Leiria District
Joined Jan 2014
Flying Wing landing skids affect stability?
http://tapatalk.imageshack.com/v2/15...7bc96b1cca.jpg
I've been flying scratchbuild wings for almost 1 year, and started to realise that on landings, after touchdown they did dive nose down, obviously because the winglets make the wing be separated from the ground, but the nose didnt.
And because i've seen some people using landing skids on front ive now build two wings with that.
After maiden yesterday and everything looking fine, today i went flying with 15kmh wind and i noticed one really big yaw instability, sometimes the wing rotates like 45degrees to the sides. Do you think its maybe the skids that create the instability??
Sorry for my bad english
Cheers, Pedro
peter97silva is offline Find More Posts by peter97silva
Old Feb 22, 2015, 02:02 PM
Joined Apr 2013
You've reduced your yaw stability by adding more vertical surface area ahead of the CG without adding an appropriate amount of area to the fins behind the CG. How much exactly is needed depends upon the moment arm from the CG (distance from CG to centroid of fin).
nuteman is online now Find More Posts by nuteman
Old Feb 22, 2015, 03:47 PM
Joined Jan 2014
So basically the best to do would be removing the skids right??
thanks
Old Feb 22, 2015, 09:04 PM
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
How about a 'wire' skid under the nose, like on the tail end of the pioneer birds (like the ever popular Eastbourne monoplane)? That might support the front without adding signifigant drag and messing up your yaw control.
Fly Wheel is offline Find More Posts by Fly Wheel
Last edited by Fly Wheel; Feb 24, 2015 at 05:34 PM. Reason: Added "under the nose"
Old Feb 23, 2015, 12:13 AM
Fremont, CA
United States, CA, Fremont
Joined Jan 2009
Some suggestions...
djacob7 is offline Find More Posts by djacob7
Old Feb 23, 2015, 02:57 AM
Team Warpsquad
Mr.Aaron's Avatar
United States, NV, Las Vegas
Joined May 2009
I've been curious about this myself and how much of an impact those tiny dubro nylon skids would have.
Mr.Aaron is offline Find More Posts by Mr.Aaron
Old Feb 23, 2015, 05:44 AM
Joined Apr 2013
Yaw stability is almost exclusively about simple geometry (other factors play a tiny role in comparison).
"Forward Torque" = Vertical surface area ahead of CG multiplied by moment arm from CG.
"Aft Torque" = Vertical surface area behind CG multiplied by moment arm from GC.
Aft Torque must be greater than Forward Torque for positive yaw stability.
I usually shoot for at least 20% more.
The trick is to get the centroid of those areas calculated correctly. For non-trivial shapes (lots of curves), this can be a chore. Rather than get an exact figure, I "estimate" the areas involved by "giving" them angular lines that only approximate the actual curvy shape.
Old Feb 23, 2015, 04:18 PM
Joined Jan 2014
Thanks guys, i think ill remove the skids.. i want it as stable as possible
Cheers
Old Feb 24, 2015, 12:57 AM
Joined Aug 2005
Have you considered a single wire skid on the nose as used on some control line planes? It's similar to the tail skid depicted in Fly Wheel's post, except it's just a wire extending down from the forward ventral area of the wing. If you've not seen them, the single wire is installed so that it angles rearward to avoid grabbing obstacles upon landing. The lower end of the wire is twisted into a small loop to avoid injury.
DT56 is offline Find More Posts by DT56
Old Feb 24, 2015, 05:33 PM
Fly Wheel's Avatar
Joined Sep 2007
Actually, that is what I was proposing (The photo was submitted by djacob) Although I should have specified in my post "...under the nose".
Old Feb 25, 2015, 11:24 PM
Joined Aug 2005
Sorry about that! I'll share the royalties with you.
Old Feb 26, 2015, 02:46 PM
Fly Wheel's Avatar
Joined Sep 2007
OK, Let's see, 15% of "free" equals...wait, let me get my calculator......
Old Feb 26, 2015, 07:23 PM
Joined Aug 2005
My spiritual adviser, Father Guido Sarducci, insists that 50 / 50 would be a deal I can't refuse.
Old Mar 02, 2015, 04:05 PM
Joined Jan 2014
Ive removed the skids and the stability got a lot better. Now i see when flying low that she doesnt fly very stable. Sometimes she drops a wingtip and that cant make me get confident when flying low. Do u think it can be the cg too far aft? Thanks
Old Mar 02, 2015, 04:33 PM
Fremont, CA
Joined Jan 2009
Sometimes it's good to provide a bit of washout on the wing tips. That means to have the wing tip twisted with the LE downwards. This forces any stalls to happen at the root first and prevents tip stall.
A CG a bit too forward is better than a CG a bit to aft.
For Sale Eflite blade CP heavily upgraded super skids landing gear, super skids boom BNF jmscard Aircraft - Electric - Helis (FS/W) 1 Jan 06, 2015 02:26 PM
Sold align trex 800e pro landing skid and stabilizer tkimbro55 Aircraft - Electric - Helis (FS/W) 1 Nov 17, 2014 03:22 PM
Sold align trex 800e pro landing skid and stabilizer tkimbro55 Aircraft - Electric - Helis (FS/W) 0 Nov 09, 2014 09:52 PM
Landing skid for flying wings? sstephenson Foamies (Kits) 12 Aug 17, 2003 10:30 PM
