Old Mar 07, 2014, 04:13 AM
United States, SC, Irmo
Joined Sep 2011
You're welcome... I am one of those "Brown Santas".
shahram72 is offline Find More Posts by shahram72
Old Mar 07, 2014, 09:50 AM
Joined Feb 2014
I hate to continue to ask questions and offer nothing in return but I have been searching and I can't believe how little literature there is on this. What size/type batteries can I upgrade to? Do I have to stay with the 7.2v 20c? or can I upgrade that? I already planned on a higher mah. Other thing I noticed is it is hard to find sky lipo batteries, every where I look they are sold out.
RCawdor is offline Find More Posts by RCawdor
Old Mar 07, 2014, 09:56 AM
Joined Feb 2014
Oh thank you sir! Always be safe and may the roads be kind to you!
Old Mar 07, 2014, 03:15 PM
Joined Sep 2011
I think any 2S lipo would be fine. Forget sky lipo, get another brand. I use the cheapest ones from ebay and they work so much better than the stock battery. What you have to know is that ESC's are not designed for lipo and will let it discharge till it's unsafe. When you notice the power loss it's too late. You need to use a $2 lipo alarm with a high enough limit so it will go off when the battery gets to no lower than 3.3v. Really this is too low. But this is what I do. The little lipo alarms plug into the balance port. Something like this..
http://www.ebay.com/itm/1-8S-Lipo-Li...item2a382a3b91
Old Mar 07, 2014, 03:27 PM
Paul Onorato's Avatar
United States, CT, Brookfield
Joined Jun 2013
Brown Santas rule!
Paul Onorato is offline Find More Posts by Paul Onorato
Old Mar 07, 2014, 04:23 PM
Joined Feb 2014
So as long as I keep it 7.2 I am good? I will get that buzzer as well.
Old Mar 07, 2014, 06:05 PM
oh that guy
United States, SC, Clover
Joined Sep 2012
I have had a lot of luck with zippy lipo batteries. They are cost effective too. First mod you should do is switch out to all Deans plugs or Traxxas plugs. Also ditch the stock esc as soon as you are able to for a lipo ready one. The stock one doesn't seem to last. Holmes Hobbies sells good ones that are cost effective for example.
slim_chance is online now Find More Posts by slim_chance
Old Mar 12, 2014, 10:39 AM
Joined Feb 2014
I found an adapter to go from the female banana 4.0 plug to male tamiya. Most of the battery packs i am seeing on Amazon and Ebay have the tamiya plug end. Unless you all believe/experienced this plug type to be problematic I plan on going this route.
I found this for the ESC upgrade eZRun-35A-RC ESC for Rock Crawler .
I am going to start off slow with my upgrades. I plan on mostly doing upgrades I found others doing in the MaxStone 10 build logs, Such as the foam cutting, re position of links and suspension, grease the diffs, water proof what is not (at least the best I can), and whatever else I come across. As parts break I plan on replacing with nice upgraded parts versus stock. The tires I plan on replacing right away though. I just haven't completely settled on a set. I am looking at these atm: Venom Beadlocks Switch Back 2.2, Hot Bodies HB 2.2 Rover Tires Blue Dot or Losi 2.2 Comp Claws Tires
I think I will get an extra set of rims as well so I can swap out the stock ones for mudding/driveway and use the others I plan on purchasing for actual rock crawling and what not. I live next to many gravel pits. Even have one on my back 40
Old Mar 12, 2014, 12:02 PM
Joined Feb 2014
Is this tire glue I am reading about really a needed item?
Ok so what I am reading is the glue MAY be needed if you are not using bead lock rings.
Sold Redcat Rockslide Super Crawler 1/8 scale ratobin Cars - Trucks and Parts (FS/W) 3 Feb 03, 2014 07:56 PM
Sold Redcat Rockslide Super Crawler New KM4BS Cars - Trucks and Parts (FS/W) 0 Dec 26, 2013 12:36 PM
FAQ Redcat Racing Rockslide XT and Rock Crawler DaftGadgets Rock Crawlers 2 Oct 23, 2013 01:48 PM
Discussion Redcat Racing Rockslide RS10 crawler special! RCTO Hot Online Deals 1 Nov 06, 2011 09:47 AM
Discussion New Twisters from Redcat Racing and free shipping on the Rockslide RS10 XT RCTO Hot Online Deals 0 Mar 05, 2011 03:25 PM
