Old Feb 17, 2013, 10:54 PM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
RCGF 15cc stock muffler and noise
RCGF 15cc engine is a good powerhouse for general use and I am very happy with it ... but OH that noise !!
It's as if the muffler is just an exhaust director with no sound reduction.
I've heard of people inserting restrictors in the outlet and so getting reduction of sound level.
I want to keep original muffler as the cowl is cut to suit ... but want to reduce the noise. Any info on restrictor / other means to do it but keeping original muffler ?
Can perforated tube be inserted into muffler can as in some silencers etc. ?
Nigel
solentlife is offline Find More Posts by solentlife
Old Feb 18, 2013, 03:32 AM
M$ Security
Joined Jun 2010
Mikarro is offline Find More Posts by Mikarro
Reply With Quote  (Disabled)
Old Feb 18, 2013, 04:38 AM
Australia, SA, Adelaide
Joined Sep 2007
have you seen these inserts http://www.dlenginesaustralia.com/dl...er-dle-20.html not sure if they that engine but it might be a easy cheap solution . Cheers the pope
the pope is offline Find More Posts by the pope
Old Feb 18, 2013, 07:05 AM
solentlife's Avatar
Joined Jan 2010
I think this is the inserts I had heard about ... interesting to actually see the fitting.
I have a metal works guy as flying pal ... so maybe I'll talk to him about knocking up an alloy insert with perforated tube to insert into expansion chamber.
As I understand it - the trick is not to impede the exhaust flow, but to bounce the sound around so it basically gets lost in the chamber ...
If it works - I will post up some pics so others might be able to follow ..
Nigel
Old Feb 18, 2013, 07:08 AM
solentlife's Avatar
Joined Jan 2010
Originally Posted by Mikarro View Post
Seeing as I'm not a Kitchen Maid ... what have pan scourers got to do with it ? Unless you mean for someone to interpret as open one up loose and insert into chamber ?
waiting with baited breath your reply ...
Nigel
Old Feb 18, 2013, 08:03 AM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
My SV-17cc engine appears to use the same can muffler. Yeah that muffler has nothing in it to help reduce noise. I made a insert baffle that I installed in the outlet tube to reduce the noise. It actually worked better than I expected too. It dropped the noise level by about two DB or so.
Troy Built models sells a insert like this for the DLE 20cc engine, which is where I got the idea from.
Before DB level without the baffle insert installed
After installing the extra baffle insert, DB noise level
earlwb is offline Find More Posts by earlwb
Old Feb 18, 2013, 12:31 PM
M$ Security
Joined Jun 2010
of course.
Sold RCGF 15cc ver 2 radfordc Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 17, 2013 05:17 PM
Discussion RCGF 15cc gasoline Engine - replace muffler ? solentlife Engines 4 Nov 12, 2012 09:42 AM
Found Stock Muffler for a RCGF 15cc Gasoline Engine! flyinjrc74 Aircraft - Fuel - Engines and Accessories (FS/W) 6 Oct 28, 2012 09:40 PM
Sold 100cc RCGF twin cylinder, stock mufflers, ign, ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 17, 2011 11:46 AM
Sold NIB RCGF 15cc engine with pitts muffler. $249 shipped in the US. 5478Jimmy Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 29, 2011 11:47 AM
