Old May 10, 2014, 08:57 AM
Joined Mar 2009
Is this thing on ???
ZED_C is offline Find More Posts by ZED_C
Old May 10, 2014, 09:07 AM
Joined Mar 2009
So I decided that I should build a boiler for my D10....
Getting material was difficult, however I had some luck with local plumbing supplies shop, they had a piece of 4 inch tube and I got it free of charge.
2 inch 16 gauge was totally different story, I ended up buying it from Maccsteam.
Sounds a bit ridiculous but it is true, had to buy a piece of copper tube from half a planet away.
I do not have drawings for this boiler, I'm basically "freestyling"
Forming the endcaps was straight forward, two timber blocks, oxy set and a lot of patience, just keep annealing the part as soon as it starts ringing when you hit it with a hammer.
Anyway, have look at the photos, any advice is welcome
Old May 12, 2014, 08:58 AM
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
From the looks of it you do not need any advise.
Regards,
Gerald.
steamboatmodel is offline Find More Posts by steamboatmodel
Old May 12, 2014, 07:30 PM
Bernouli effect is overrated
Daedalus_'s Avatar
Joined Apr 2014
Thanks Gerald,
I can find my way around workshop easily , but I also believe that all people know everything, single person does not.
Is there any rule for smokestack size ? I intend to use 32 mm dia. tube.
Entire boiler will be 290mm long, am I overdoing things here ?
Regards
Zelko
Daedalus_ is offline Find More Posts by Daedalus_
Old May 14, 2014, 10:26 AM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi.
Most of the boilers I have seen have a flue that is smaller than the fire tube , I would guess by about a third. Not sure why , but I am guessing it is an attempt to get all that nice heat to stay in a little longer.
Don't forget to use higher melting point rods for the burner tube and slightly lower for the ends, like I didn't first time round and had silver solder melting all over the place
Nice engine by the way.
Dunc2504
dunc2504 is offline Find More Posts by dunc2504
Old Aug 18, 2014, 10:12 PM
mistairjoe's Avatar
lake orion mi
Joined Sep 2002
any updates???
mistairjoe is offline Find More Posts by mistairjoe
Old Nov 16, 2014, 03:20 AM
Joined Mar 2009
Still making progress, just finding it difficult to find free time.
Anyway, I managed to silver solder the boiler. Everything went quite well...
I drilled and tapped only one journal, that way there is no extra holes to plug for pressure testing.
And, I have to bore a hole for a chimney/smokestack/funnel.
Old Nov 18, 2014, 10:55 PM
Steamy laser dude.
SenorNeekers's Avatar
Canada, BC, Victoria
Joined Oct 2011
Looking good so far!
SenorNeekers is offline Find More Posts by SenorNeekers
Old Jan 09, 2015, 06:23 AM
Melbourne, Australia
Joined Mar 2009
Originally Posted by ZED_C View Post
Today's exercise was making cylinder covers. There are only steam chest covers and the flywheel left as far as Cast Iron parts are concerned.
Soon I will have to start working on the crankshaft, I think that I will take Loctite and pins approach. I don't like the idea of soldering because of possibility of distortion.
Can someone please tell me about the pins, are they small dowels ? Where can I get them from ?
Also I am considering making counterweights on crankshaft webs, did anyone try doing this ? I think that it will add to the dynamics/appearance of the engine, maybe even make it a bit smoother.
I tapped the gland ports M8 x 1.25 (a. Because I had a tap handy, and b. Because I only have metric change gears for my (imperial) Chinese lathe.
Love the captions... Took me a couple of posts to realise you were piss taking.
Cheers,
Hugh
Ps. I have turned up a couple of cranks for these engines now from forged blanks. It's easier than it looks.
MerlinV is offline Find More Posts by MerlinV
Discussion Yet another GhostQuad Thread Mochaboy Multirotor Talk 0 Nov 08, 2012 11:17 AM
Discussion Yet another "what is it" thread... bassfisha Fuel Plane Talk 2 Oct 22, 2012 10:26 AM
Question Yet Another "What do I buy" thread AbeFM Micro Helis 19 Jul 31, 2012 09:27 AM
Help! Yet another NAZA arming thread ivers Multirotor Talk 20 Jul 14, 2012 12:46 PM
