Old Dec 03, 2012, 03:39 PM
I'd rather be.....
geoffers0_0's Avatar
Bristol, UK
Joined Jun 2008
Picasim now available for Windows
http://www.rowlhouse.co.uk/PicaSim/
Woo-hoo : up and running on Windows - much the same as the Android version, but YOU CAN USE A TX (or USB controller) as the input device
Not fiddled much with the settings yet, but to get you started
In Joystick, check "Enable Joystick", then these mappings worked for me
  • Joystick 0 : Right Stick Horiz : Scale -1.0
  • Joystick 1 : Right Stick Vert : Scale +1.0
  • Joystick 2 : Left Stick Vert : Scale +1.0
  • Joystick 4 : Left Stick Horiz : Scale -1.0
In Controller, I've set the Left Stick Vertical Movement Scale to Zero (off) as Crow brakes aren't really needed on a Sim
Problem with having this to stick setting turned on control flaps is that the stick mid-point is neutral: stick forward is full up-flap(spoiler) and stick back is full down-flap (crow). I like flying with stick forward as the neutral position, and stick back as full crow brakes, but haven't found how to do that yet
geoffers0_0 is offline Find More Posts by geoffers0_0
Old Dec 03, 2012, 05:12 PM
Alphabets make great soup
Hamburglar's Avatar
Australia, QLD, Toowoomba
Joined Jul 2008
Cool. Thanks for posting.
Do you know how blow it up to full screen?
Hamburglar is offline Find More Posts by Hamburglar
Old Dec 03, 2012, 06:05 PM
I'd rather be.....
Bristol, UK
Joined Jun 2008
I found you can drag the window corners to grow the window - the restore-up button on the right doesn't maximize but dragging works.
I think that Danny is treating this as a Beta version, and is happy to take criticism / requests for improvement etc - details here http://picasim.freeforums.org/now-av...ndows-t28.html
Old Dec 03, 2012, 06:28 PM
Hamburglar's Avatar
Joined Jul 2008
Cool. Thanks for that.
Old Dec 04, 2012, 12:16 AM
Aerobatics!
JGAF's Avatar
United States, CA, Big Bear Lake
Joined Nov 2007
Hey so I got this working on my xbox 360 controller, the only issue is my up and down is reversed.. I just decided to fly the fish upside down at this point but it would be cool to have it the right way around.
Is there any way to reverse channels?
I should read before I post; set up the controller with Danny's settings above and everything is working fine
JGAF is offline Find More Posts by JGAF
Old Dec 04, 2012, 12:55 AM
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
Hmm..just gets stuck on the loading screen for me. Won't run.
bjaffee is offline Find More Posts by bjaffee
Old Dec 04, 2012, 07:24 AM
Mr Rowl's Avatar
United Kingdom, England, Oxford
Joined Jul 2002
Yes - sorry about this. It seems to be hitting a small but significant proportion of machines - not necessarily low end ones either. Updating graphics card drivers might help... (but I have no evidence yet that it will).
To fix it (I hope), and also allow running full screen, I need to rewrite some of the graphics code. Hopefully that will happen fairly soon.
I'm hoping that people might start tinkering with the planes and sceneries - it's pretty straightforward, and I'm happy to explain anything.
Mr Rowl is offline Find More Posts by Mr Rowl
Old Dec 04, 2012, 01:04 PM
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
Mine's an Intel I7 920 with a Radeon 6870 video card, fwiw. Fairly high-end when it was new 2 years ago, but I guess it's probably middle-of-the-road now.
Old Dec 04, 2012, 01:07 PM
Mr Rowl's Avatar
Joined Jul 2002
Unfortunately (in a way) it's not about power - that card would easily be able to handle it. It's purely about whether the system that converts OpenGL ES to OpenGL works with it. That part will change. Soon. I promise!
Old Dec 06, 2012, 10:21 AM
perttime's Avatar
Tampere, Finland
Joined Nov 2004
Works fine on my old XP machine.
Here's a couple of things that are not quite perfect for me:
- using a mouse for control, I have no tactile feedback of what I'm doing. In some simulators, I do sort-of-OK using arrow keys for control.
- The plane and site selection screens look like there'd be more than 3 selections but I have no way to scroll down.
- My mouse pointer sometimes disappears when it is over the simulator.
perttime is offline Find More Posts by perttime
Old Dec 06, 2012, 10:25 AM
Mr Rowl's Avatar
Joined Jul 2002
Originally Posted by perttime View Post
- using a mouse for control, I have little tactile feedback of what I'm doing. In some simulators, I do sort-of-OK using arrow keys for control.
Yes - the best way is with a joystick, Tx interface or gamepad...
You can click and drag (it's rather obviously a port of a touchscreen app!). Also, I uploaded a new version a couple of hours ago that enables the mouse scroll wheel in the selection screens. It also adds one more plane - I think there's 18 in total...
Weird - I've never seen that one!
Glad it's mostly working though!
Old Dec 06, 2012, 06:36 PM
I'd rather be.....
Bristol, UK
Joined Jun 2008
aha - that was one thing I was going to ask for...
Also - is it possible to set the left-stick-vertical (spoiler/crow setting) so that stick fully forward=no braking, and stick back= full braking.
At the moment it seems to me that stick-centre=no braking, but stick-forward = braking (spoiler up) and stick-back = braking (flap down/crow)
Old Dec 06, 2012, 07:13 PM
Mr Rowl's Avatar
Joined Jul 2002
It varies depending on the model. Some just have flaps that go up or down depending on the stick offset from centre (e.g. Le Fish, Phase 6) but now I check, some (e.g. the Banana) are just odd... Generally I need to go through and sort them out.
Yes it is (fortunately = I'd never tried it before)! The equation is:
control = trim + (input ^ exponential) * scale
and the input ranges from -1 to +1. With the default settings the output will range from -1 to +1 too.
So - in the controller settings (advanced), scroll down to the left stick vertical. Then set:
exp = 1.0
trim = 0.5
scale = 0.5
spring = false
Then the output maps from 0 to 1 i.e. with the stick down there's no flaps/spoilers, with it up, they're full on (flaps up or spoilers on).
If instead you adjust (as well as exp and spring)
trim = -0.5
scale = -0.5
Then the output maps from 0 to -1 i.e. with the stick down there's no flaps/spoilers, with it up, they're full on (flaps down or spoilers on).
What you want, I think is:
trim = -0.5
scale = 0.5
Then the output maps from -1 to 0 i.e. with the stick down flaps are down/spoilers on, and with it up there's no flaps/spoilers.
I hope that makes sense! In the future hopefully there will be a full mixer setup that's easier to use (at the moment some of that goes on in the model definition, so isn't easy to adjust - even things like snap flaps). Also, many planes need a fifth analogue channel really. And as I say - this control aspect needs some attention on pretty much all the planes.
Old Dec 06, 2012, 08:32 PM
Gravity sucks
SrWade's Avatar
United States, WA, Richland
Joined Mar 2006
I've downloaded the installer, but it does not seem to want to install the program on my Windows 7 machine.
SrWade is offline Find More Posts by SrWade
Old Dec 07, 2012, 06:41 PM
Feeling FrSky
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
That's a 4-axis setup... PicaSim is as far as I know the only way you can play around with what that setup is like, outside of setting up a real-life glider to fly that way.
Steve
surfimp is offline Find More Posts by surfimp
Discussion Airware 2.06 update now available for DX8 crvnation Radios 35 Apr 19, 2014 06:01 PM
Discussion GoPro App now available for iphone, had anyone tried it yet? crd FPV Talk 0 Oct 09, 2012 10:03 AM
Discussion Scorpion Ultimate Motor now available for SAB Goblin 700 Innov8tive Electric Heli Talk 1 Aug 24, 2012 08:17 PM
Discussion PicaSim: New simulator for Android devices Mr Rowl Simulators 0 May 17, 2012 12:21 PM
