Old Aug 31, 2012, 08:18 PM
UH-60 Blackhawk Mechanic
helifrek's Avatar
United States, TN, Clarksville
Joined Feb 2004
DX6i charging question
Hey guys, I recently bought a DX6i from a fellow member and it did not come with a charger. No big deal, I have a spektrum charger but I think it came with my old DX7. the output on the charger is 11.6V 110mah...... the DX6i is 4.8 volts of course...... well, the output on the RX side of the charger is 5.8V at 110mah. should I switch out the charging jack and charge the DX6i through the RX side of the charger (5.8V) or just go ahead and plug it into the TX side of the charger? I know plenty about lipos but not much about NiCd and NiMH batts. I would assume I should charge it at 5.8V but..... figured I would ask you experts on here first thanks guys.
Brandon
helifrek is offline Find More Posts by helifrek
Latest blog entry: 3D Printing services!
Old Aug 31, 2012, 10:18 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Rx side. You don't want to charge NiXX packs to 11.6V. These chargers do not shut off, they keep charging. As they reach the rated voltage the current gets very low and they can be left on for a reasonable time after the pack is charged without damaging the pack. Leaving it plugged in at an 11.6V level would damage the packs.
hoppy is offline Find More Posts by hoppy
Old Sep 01, 2012, 10:06 AM
Barbados
Joined Jan 2011
But Hoppy you did'nt tell him what to do,yes use the Rx side of the charger it's set up for a 4 cell pack,you'll have to solder on a plug or make a Tx plug to a futaba and plug in.
The Tug is offline Find More Posts by The Tug
Old Sep 01, 2012, 12:55 PM
helifrek's Avatar
Joined Feb 2004
I know I would have to switch plugs, no big deal there. I just wanted to make sure I am charging it at the right voltage thank you very much.
Brandon
Old Sep 01, 2012, 10:08 PM
United States, FL, Clearwater
Joined Jun 2009
Be careful with the polarity of the TX batt pack. The DX6I TX has the (+) attached on the outside of the plug, I think ?
charlie
cbinfl is offline Find More Posts by cbinfl
Old Sep 02, 2012, 10:44 AM
helifrek's Avatar
Joined Feb 2004
Will do. Thanks.
Brandon
Old Sep 02, 2012, 04:32 PM
Joined Aug 2012
My dx6i charger says 5.5 VDC at .15 A.
Matt Ls Thumbs is offline Find More Posts by Matt Ls Thumbs
Discussion Battery charge question, first time charging at 5C internal temp was 117 degrees jasper7821 Batteries and Chargers 14 Sep 20, 2012 10:55 AM
Discussion Spectrum DX6i Charging Jack Stopped Working - How To Fix? itsme2 Radios 2 Aug 13, 2012 09:21 AM
Question Spektrum Dx6i Battery Charge brettossman Radios 2 Jun 16, 2012 08:12 PM
Discussion dx6i charging question: any indicator? 4getr34 Radios 3 Nov 20, 2011 11:31 AM
Question Spektrum dx6i charging question Thermalin Radios 13 Aug 15, 2010 10:57 PM
