Old Jun 22, 2012, 10:09 AM
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Free Plans for Lasercut Frames / mounts?
I've been searching quite a bit and I'm unable to find a Autocad file with plans for a simple frame and or mounts for a perspex or even plywood.
Does anybody know of such a resource? I have a laser cutter at my disposal and nothing to cut
heinduplessis is offline Find More Posts by heinduplessis
Old Jun 29, 2012, 09:12 PM
Hkubota's Avatar
Japan, Tokyo
Joined Mar 2012
http://diydrones.com/profiles/blogs/...g10-quad-frame
I know if I had a laser cutter I'd make a frame, see what is good or bad. And use FEA to find out where stress points are while at it.
Hkubota is offline Find More Posts by Hkubota
Old Jun 30, 2012, 10:52 AM
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
Originally Posted by Hkubota View Post
Were you actually able to find the DFX files on that site? I followed his link to the Instructable, but I cant; find the DFX files there.
-K
kad is offline Find More Posts by kad
Old Jun 30, 2012, 12:26 PM
Sunny Phoenix, AZ
Joined Feb 2004
I have a laser cut frame design that I've built several times - it works pretty well. It is a quadcopter frame at about 420mm motor-to-motor spacing, built out of 1/8" plywood. I'd be happy to send you the files if you'd like.
Regards, Jon.
jmdhuse is offline Find More Posts by jmdhuse
Sold Plans for prophet 941 and aquilla wing plans-free radman615 Aircraft - Sailplanes (FS/W) 5 Mar 07, 2012 08:04 PM
Build Log RadicalRC lasercut tricopter frames: the prototype burg911 Multirotor Talk 12 Nov 15, 2011 12:36 PM
Build Log Building without plans or lasercut ribs ChuckA Thermal 65 Nov 04, 2011 07:47 PM
Discussion HOUSTON HAWK plans, lasercuts, fuselage? PeterH Sailplane Talk 22 Aug 12, 2008 12:01 PM
Question Interest of free lasercut files? Patrik N Parkflyers 13 Mar 26, 2008 01:28 PM
