Old May 02, 2012, 12:07 AM
Joined Oct 2011
KAP - on Night Rainbow Delta Box
Will do a test flight to see if it works...
lanternfly is offline Find More Posts by lanternfly
Old May 02, 2012, 05:19 AM
Joined Jun 2006
Lanternfly, as a very interested aerial photographer, KAP enthusiast etc etc I am very interested in your project. I would very much like to know the weight of the camera in gms, wingspan of the kite, overall weight etc and of course I hope! to see some great results. Good luck.
Ted (UK)
tedrobphoto is offline Find More Posts by tedrobphoto
Old May 02, 2012, 12:31 PM
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
hi lanternfly,
with a camera-weight of 10-150 grs (... I guess)., mounted on top of the tension-bar, You'll move the horizontal CoG much vertical up from where it is in the 'normal' case.
Worst case: The dehidral of your Delta-Box is not able to neutralize that massive vertical CoG - movement - and Your Delta-Box flies upside-down - or makes wild shakes in the air, badly to control.
I've mounted last year my canon Powershot SX 120 on the opposite site of the LiPo-velcro, of my 300cm Delta Box, near the CoG, and it workted fine. The Delta-Box was more stable then, but the motor had much more work to keep the kite in the air.
flattermann
flattermann is offline Find More Posts by flattermann
Old May 06, 2012, 11:36 AM
Twisted Sheets's Avatar
The Gorge - Oregon USofA
Joined Sep 2006
Flatterman, I too have a Delta Box and think it could be a good kite for KAP, both as a powered kite and as a single line kite.
KAP gear could be attached to the single line harness (under the kite).
What do you think?
Twisted Sheets is offline Find More Posts by Twisted Sheets
Old May 07, 2012, 12:00 AM
Joined Oct 2011
Hi flattermann,
I have tried flying it with the camera attached, it can fly but not stable.
The video captured was not smooth and clear as the kite is like going through
roller coaster.
Will re-attach to another position and re-fly again.
Thanks for your comments.
lanternfly
Old May 21, 2012, 02:29 AM
Joined May 2012
Hello,
I've read many things about Delta Box Vector kite. I would like to use this kite to take photos (not videos).
I wonder if :
I can install a GoPro (regarding the weigh of this camera)
The Delta Box can fly slow enough so the photos are not "vague", I mean good quality
Thank you
Sylvain (from France, so my english is not so good)
Boro is offline Find More Posts by Boro
Old Dec 30, 2012, 04:18 AM
Joined Oct 2011
Here's my video recording attempt on the RC Vector kite...
Flying above carpark (2 min 47 sec)
Sold Night Vapor RTF w/Transmitter in Box - $80 Free Shipping! Jeff Worsham Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Apr 23, 2012 06:43 PM
Build Log Night Razor - 22 inch delta (with plans) slebetman Foamies (Scratchbuilt) 22 Mar 15, 2012 04:43 AM
Discussion Premier Delta Box RTF For Sale Twisted Sheets RC Kites 2 Sep 14, 2011 06:55 PM
Idea Shoe Box Delta Flier RET indoor delta/PBF with Video tymbrewolf Foamies (Scratchbuilt) 21 Dec 16, 2010 10:04 AM
LED configuration for night flying on Delta wing? rocstar Foamies (Kits) 7 Oct 21, 2004 12:09 PM
