Old Apr 19, 2012, 08:05 PM
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
Question
COG question...
Tonight was a beautiful night for trimming. Approximately 2 mph wind, 60F, and no clouds. Flew my E-Pulsar 3.2 REF about 45 minutes before sundown in what appeared to be zero lift. I tried different elevator trims and I think itís about optimum for speed above stall and flatness of glide. Sink rate (L/D) looks to be in the 90 fpm range which I think is nearly twice what other folks have been reporting. I havenít done dive testing for COG yet Ė Iím a little scared. Love the way this plane flies. Does COG position affect L/D or is COG position mainly used to have sailplane single weak lift? Open to suggestions. Thanks in advanceÖ
Piper J3
Piper J3 is offline Find More Posts by Piper J3
Old Apr 19, 2012, 08:29 PM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
A properly located c.g. will have the least trim drag for the speed.
Dive test... be gentle.
Get trimmed, push over lightly, not full down! Watch what happens.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Apr 19, 2012, 08:31 PM
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
Am I right that 90ish fpm sink rate is a bit high for Pulsar 3.2?
Old Apr 19, 2012, 10:38 PM
HomoDilatus
kcaldwel's Avatar
Joined Jan 2007
Min sink speed will be slower than best glide speed by a couple of kph. Min sink speed is just above stall speed, so you may have to try slowing it down more if you are flying at best L/D.
CG position, within the range usually used on RC sailplanes, will make very little difference to performance. Depending on the exact configuration, minimum trim drag should be at about a 5% static margin for a conventional lay-out with a stab about 20% the span of the wing. This is reasonably pitch stable. If you get the CG back near the neutral point, all the control deflections required to try and hold a speed, and speed changes, will cause the performance to get worse.
Turning will really increase the sink rate. Most sink rate tests are done by flying as straight as possible. Either fly straight out as far as you dare and make a very gentle turn back, or fly a large rectangular circuit with very gentle turns.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Apr 20, 2012, 08:44 AM
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
From the master:
http://www.polecataero.com/handlaunchu/cg-location
Curtis Suter is offline Find More Posts by Curtis Suter
Old Apr 21, 2012, 11:34 AM
HomoDilatus
kcaldwel's Avatar
Joined Jan 2007
This is a good illustration of glider polars and the various optimum speeds:
http://www.5c1.net/Glider%20Performance%20Airspeeds.htm
Kevin
Old Apr 22, 2012, 10:57 AM
Mobile, AL
Joined Jul 2008
? for cloudyifr
Mark Drela's commentary on CG is his usual carefully crafted, lucid explanation.
As I understand it, the dive test results depend on the position of the elevator trim in cruising level flight. If the decalage is correct and the CG is at the rear limit of neutral stability, then the elevator should be in neutral in that flight state; is that correct. Should the decalage be incorrect, then the whole concept is screwed up. I am having a chicken or the egg problem with this.
Lloyd
lloyd3521 is offline Find More Posts by lloyd3521
Old Apr 22, 2012, 11:02 AM
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Lloyd
Imagine that the elevator is a full flying elevator... then your problem disappears.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Apr 22, 2012, 11:43 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
Lloyd
Whatever the decalage, from a trimmed condition, a sufficiently nose heavy plane will self recover from a dive test.
You can play around with c.g. and decalage to get a different response.
But don't push into a vertical dive! The wingtips can meet over the center of the airplane!
Old Apr 22, 2012, 11:48 AM
HomoDilatus
kcaldwel's Avatar
Joined Jan 2007
Lloyd
"Decalage" and elevator position are the same thing. If the trim speed is correct, through either setting the elevator or stab angle, then the dive test results will get you in the ball park for the CG. The elevator deflection to get to the trim speed doesn't matter, and makes essentially no difference to the performance either, as long as it isn't huge.
There are bunch of secondary effects such as the MAC and drag centre being raised way above the CG by dihedral, low Re effects, stab airfoil hysteresis, etc., that make the dive test less than completely reliable.
Adjust the CG position for the pitch stability you like from the glider pitch behaviour. Don't forget the reduce the elevator throw as you move the CG back, because leaving large throws can make the glider seem skittish in pitch with aft CG when it is really just too much elevator throw. The elevator gets more effective with aft CG. Trim speed is then set with the elevator. If you end up with large elevator deflections for trim, you may want to change the stab or wing incidence to get a more neutral elevator at trim. Unless the trim deflection is quite large, it makes no difference to the glider performance, and it makes no difference to the glider behaviour unless there is a secondary problem of a poor stab airfoil or something.
Kevin
Old Apr 22, 2012, 11:59 AM
Red Merle ALES
Joined Apr 2002
Kevin,
Nice explanation! I often hear where folks think that small elevator deflections for their straight and level flight make a big difference but as we know they do not.
Here is a document from Dr. Drela I saved that confirms this:
A more precise and technical answer is reprinted below from Mark Drela in the Allegro-Lite YAHOO group, message #6005;
The importance of decalage is way overblown.
First of all, if you have an all-moving tail, then obviously "setting
the decalage" has no meaning. You just set the elevator trim to
whatever it has to be for your CG position and desired trimmed speed.
It turns out that for a hinged elevator, decalage should also have
little effect. You can change pitch trim either by moving the
elevator or moving the entire tail. There should be little or no
difference in pitch stability or elevator response between the two
types of changes. This assumes that the tail airfoil is reasonably
good, and the elevator deflection is modest so that the tail's
cl(alpha) and cl(elevator) curves are still linear. The only reason
to change the decalage (angle of the front stabilizer) in this case is
to null out the elevator trim deflection. This will give more
symmetric elevator range, reduce elevator servo load at high speed,
and perhaps reduce the tail's profile drag very slightly.
If there IS a difference in handling from a change of decalage, then
you surely have poor airfoil flow over the tail, with some combination
of dead band or hysteresis. This also indicates the presence of large
separation bubbles and high profile drag. A simple slab airfoil with
a semi-circular LE is very common, and is prone to these types of
problems. Making the LE more elliptical rather than round should give
a significant improvement.
Curtis
Montana
Old Apr 22, 2012, 12:02 PM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
If a reasonable dive results in a very slow recovery and it takes little down elevator to fly inverted, the CG is pretty close.
But then CG is like spicy foods, it's pretty much to each individual's taste.
tkallev is offline Find More Posts by tkallev
Old Apr 22, 2012, 02:52 PM
Mobile, AL
Joined Jul 2008
To Kenny Sharp
Tried to engineer a flying stab and consistently fail to get the lateral rigidity I find acceptable. Should have studied engineering or else quit trying to design my own.
Thanks all.
Lloyd
Old Apr 22, 2012, 04:52 PM
Zor
Ontario,Canada
Joined Feb 2007
Thanks all.
Lloyd
If a cantilever main wing can be engineered to stand the full lift forces including high G forces then a flying horizontal tail surface can be using the same techniques.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Discussion Newb question: COG / Swift II Blue Chip FPV Talk 2 Mar 16, 2012 10:20 PM
Question 22.5" EDF wing COG Question RC flight Flying Wings 5 Jan 25, 2012 12:53 AM
Irvine Wildcard and COG question Gavin M Fuel Plane Talk 2 Apr 25, 2005 07:24 PM
C47(DC3) cog question conder53 GWS (Grand Wing Servo) 3 Aug 07, 2004 11:56 PM
COG.. Question BrokinBalsa Foamies (Kits) 10 Mar 27, 2004 03:13 PM
