Dec 06, 2005, 07:20 PM
Joined Feb 2005
Right unto the Ultimate box, there is no less than 4 brushless motor recommendations, the least powerful option in the lot being the C/13/28, then all the way up to the B/18 series.
A more powerful motor requires more powerfull battery too, and that also means more weight (not to mention more $$$)
The C/13/28 is a powerful yet very light motor. It will fly the Ultimate well, although with not as much power that the bigger options. It's an all around versatile motor, with a gearbox, and as such is stick mounted. That means it can be used as is in most any plane using a stick without any modifications whatsoever.
Now given a typical 10C rated (12C bursts) 3s 2100 lipo, the best option for maximum power IMO is the B/12/10. Will give you up to 240-250 watts bursts on that battery with smooth direct drive and a large prop. Motor weighs 65 grams, and of course, the Ultimate box contains everything you need to fix it right to the firewall. It is a little bit more expensive than the C/13/28, but not all that much. (Note : make sure when you order this motor that the aluminum cross mount is included with the motor... a few of them motors were shipped to LHS without it).
