Old Mar 06, 2015, 07:10 AM
Jaxle67 is offline
Find More Posts by Jaxle67
Joined Feb 2015
adding leds
This may be the weeping place to ask but here goes. I would like to add some Leds to my plane but unsure hour to power them. Can I hook to say up to an aux channel and run of the receiver so I can switch on and off as needed. I'm pretty good at electronics but new to the rc planes. Or do I have to go some other route. I'm using a 11.1lipo by the way. Thanks for any input. Jesse
Jaxle67 is offline Find More Posts by Jaxle67
Old Mar 06, 2015, 07:15 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Don't run run gadgets and gimmicks from something that important as receiver/servo power.
Prettig weekend Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Mar 06, 2015, 07:24 AM
iwlf is offline
Find More Posts by iwlf
United States, NC, Troy
Joined Dec 2008
Ron van Sommeren's comment is well-advised, however, it depends on what you're trying to power.
A couple nav light LEDs don't draw enough power to be a factor unless you're already taxing your rx power (i.e. servo power for flaps, dual ailerons, elev, rudder, ) and you should check the total power requirement for all devices against what your ESC/BEC is putting out.
You can easily run a separate power source for the LEDs (they don't take much) and use the proper resistors to control voltage.
To operate the lights remotely you will need a receiver controlled switch (like this one from HK) and a channel to run it.
I've used both methods (rx powered nav lights on my Waco and PA-28, separate power for more intense night flight lights) without issues.
Have fun!
iwlf is offline Find More Posts by iwlf
Old Mar 06, 2015, 07:52 AM
Glacier Girl is online now
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Yep LED's can be run from a seperate pack or even from the main pack.
I had a Slow-V with 50 lamps on it and I ran if from an old cell phone battery (1S).
Could run an easy half hour on it.
My Slow Stick pulls it's pwer from the main pack, (3S) Tied into the balance connector, for 12volt power. I do not advise using less then the 12 volt side of a 3S pack as you can pull down the cells unevenly.
Just a materr of the correct resistors for the voltage you use.
And if you don't want to buy a switch an old servo can be rigged to do the same.
Glacier Girl is online now Find More Posts by Glacier Girl
Old Mar 06, 2015, 07:54 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Check out the Night Flying forum for all kinds of lighting ideas: http://www.rcgroups.com/night-flying-522/
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Mar 06, 2015, 08:14 AM
Jaxle67 is offline
Joined Feb 2015
Thanks for the info. There is really nothing but just basics hooked to the receiver but u will take the advice And run seperately. Jesse
Old Mar 06, 2015, 09:16 AM
Joined Feb 2001
Originally Posted by Ron van Sommeren View Post
Don't run run gadgets and gimmicks from something that important as receiver/servo power. ...
If something goes wrong in that non-essential gadget, you crash.
Prettig weekend Ron
Old Mar 06, 2015, 07:36 PM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
true... but ive been running led lights from these planes without issue. y harness to throttle channel. minimal draw. works great. many flights. YMMV.
walter3rd is offline Find More Posts by walter3rd
Discussion Adding led to a Foamy darticus Electric Plane Talk 5 Nov 05, 2014 02:11 PM
Discussion Naza M V2 LED flashes red when adding throttle sforl Multirotor Electronics 3 Oct 25, 2014 01:47 AM
Discussion Adding LED's swimmer Electric Plane Talk 5 Oct 10, 2014 10:03 PM
