Old Mar 23, 2014, 02:28 PM
dk31 is offline
Find More Posts by dk31
dk31's Avatar
Athens
Joined Oct 2009
Question
PU vernice + Baby powder as primer
I don't know if this is the right place to ask but anyway.
I ve been experimenting covering foam with light Fiberglass cloth (I tried both epoxy resin and PU vernice).
Right now, I am trying to get rid of the "cloth look" and achive a nice glossy wing surface (before applying paint). I tried the "PU vernice + Baby powder" method and I only get acceptable results when:
1. Mix 1 part vernice and no less than 2 parts powder
2. When squeezing off the excess, I dont push the squeege (spatula) against the wing - just hold the squeege very lightly
Is this the way it works? I 've only tried 2 layers of primer so far and before the above two actions, it looked like 5 layers wouldn't be enough
dk31 is offline Find More Posts by dk31
Old Mar 23, 2014, 04:29 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
I think you might do better by posting in the Painting and Finishing forums.
However, I'll answer the best I can for the time being.
I've Googled "PU Vernice", but cannot find any description. What is it please?
The closest definition I could find was a reference to traditional Violin finishing using a mixture of egg white and Gum Arabic!
Talc is ground Magnesium Silicate rock and as such, is heavy. It is ok for non-flying components such as plugs for mould construction and the like. However, I consider it too heavy for flying parts. For the job you are describing, I have used primer and ""Q" cells mixture with some success. Wet sand in between applications.
To minimise the voids in the first place, a sheet of mylar or another plastic (waxed first) applied on top with some pressure will work. Vac bagging is the most effective way to do this, but you may not have the equipment to do this. There are many vac bagging threads to be found here.
Also, you don't mention what kind of foam you are using?
All relevant details are always helpful for the reader when asking questions on these forums.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Mar 23, 2014, 04:55 PM
dk31 is offline
dk31's Avatar
Athens
Joined Oct 2009
Thanks for your time..it looks like I have messed up definitions
PU vernice --> Polyurethane lacquer
primer and ""Q" cells mixture --> what primer and what's "Q-cells"?
The foam I 'm working with is EPO sanded to a smooth finish. There are no voids - the only thing I want to smooth out is the pattern/weave of the FG cloth (3/4oz cloth).
Here is another thread describing this technique (post #9 mostly) - he just uses polycrylic instead of PU lacquer
http://www.rcgroups.com/forums/showthread.php?t=161218
Last, vacuum bagging is out of the question for the moment...
Old Mar 23, 2014, 05:07 PM
Joined Aug 2008
Q cells are micro spheres used widely in the composite industry. Go to your local fibreglass shop and they might sell you a small quantity. Otherwise, buy online I suggest.
"the only thing I want to smooth out is the pattern/weave of the FG cloth (3/4oz cloth). "
I would use several application of spray putty with wet sanding in between.
If you don't have a spray gun, thinned nitro-cellulose "stop putty" applications using a scrap of plastic sheet as a screed would also work. It will involve more sanding, that is all.
Old Mar 24, 2014, 02:23 AM
dk31 is offline
dk31's Avatar
Athens
Joined Oct 2009
Thank you Jim.
I guess the Q-cells/micro spheres are the same material as micro-balloons (AKA glass bubbles). There's a local shop that sells them but I have never tried them so far. I ll check the weight increase with the talc and try the micro-balloons to compare
Old Mar 24, 2014, 03:28 AM
Joined Aug 2008
Originally Posted by dk31 View Post
Thank you Jim.
I guess the Q-cells/micro spheres are the same material as micro-balloons (AKA glass bubbles). ......................e
In practical terms, yes. Just slightly different manufacture and price.
Generally called microspheres......
Old Mar 24, 2014, 05:22 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You should check in the Scratchbuilt EDFs forum, lots of guys there use WBPU==water based Polyurethane ..
Just do a search for wbpu.
Search this thread too, John is an excellent builder
http://www.rcgroups.com/forums/showthread.php?t=2033785
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Mar 24, 2014, 08:18 AM
T_om is online now
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
I think the word you are looking for is "varnish", polyurethane varnish.
There are a LOT of combinations of materials used for filler. Keep in mind that micro balloons/micro spheres/any micro bubbles does not usually make a good, ready to finish, final surface. I prefer talc personally. Everyone has their favorite materials and talc is what has worked for me since the days of nitrate dope. Talc works with dope, polyurethane, and epoxy... basically anything. I just like it.
Tom
T_om is online now Find More Posts by T_om
Old Mar 24, 2014, 04:08 PM
Joined Aug 2008
There you go DK, Tom likes the talc and also I think polyurethane varnish is what you are looking for.
If I am correct, Tom builds discuss launch gliders (is that right Tom? - maybe I have the wrong Tom?).
The DLG building fraternity have much to teach us about composite construction.
At five years into the hobby, I consider myself about a 4th year apprenctice!
By the way, industrial talc from composite suppliers is cheap and perfume free.
Old Mar 24, 2014, 11:52 PM
AUSELECTRIC is offline
Find More Posts by AUSELECTRIC
Joined Nov 2004
I think Mylar as Jim suggested may help reduce the look of fabric, just remember to keep it on until the part has cured.
AUSELECTRIC is offline Find More Posts by AUSELECTRIC
Old Mar 25, 2014, 01:15 AM
dk31 is offline
dk31's Avatar
Athens
Joined Oct 2009
I think mylar and other films is not a good base for paint. Right now, I am experimenting with the FG cloth/primer/paint combination to see how I can improve EPO in terms of stiffness, hangar abuse resistance and nice finish colored surfaces. I have seen state of art constructions with films and even packing tape, but that's something to try another time
So, my first results show an increase in weight around 5% for every additional layer of WBPU+Talc. Tom, do you have any good recipe for the mixture? (like the 1 part WBPU and 2 parts talc I am talking about in the first post)?
Old Mar 25, 2014, 02:13 AM
Joined Aug 2008
[QUOTE=dk31;27887552]I think mylar and other films is not a good base for paint. ...................../QUOTE]
The mylar sheet is not left on the part! It is removed after the epoxy cures.
I suggest a read of one or two of the vac bagging threads might clarify this.
Old Mar 25, 2014, 12:44 PM
dk31 is offline
dk31's Avatar
Athens
Joined Oct 2009
It's clear to me now It's the first time I hear about using a film + pressure on epoxy without involving vac bagging
Thanks again all and everyone for your replies
Discussion What brand of foam safe spray can I use as a primer that I can buy in Australia? corellian_yt1300 Australia 5 Jan 14, 2014 03:43 AM
Discussion Government Shutdown: 9 Million Moms And Babies At Risk As WIC Program Halts Broken Wings Life, The Universe, and Politics 51 Oct 03, 2013 08:36 PM
Discussion baby powder ratio? Maz Painting and Finishing Tips 4 Aug 25, 2007 03:57 PM
What kind of Baby Powder for WBPU? rdeis Parkflyers 5 Nov 08, 2004 08:32 PM
WBPU And baby Powder? kushal_22 The Builders Workshop 3 Jan 29, 2003 04:30 PM
