Old Feb 26, 2014, 09:27 PM
devinvagt is offline
Find More Posts by devinvagt
United States, CA, Ukiah
Joined Jan 2011
vtol tailsitter starter PID values?
Hi all,
I'm working on a tailsitter vtol uav and getting some oscillation from the elevons, I think it's feedback from the multiwii board but not sure yet. I'm hoping I can minimize with adjustments to the PID values but I'm just making a guess until I know more about how PID control works. Any suggestions for starting out?
Devin
devinvagt is offline Find More Posts by devinvagt
Old Feb 26, 2014, 11:49 PM
jolyboy is offline
Find More Posts by jolyboy
Australia, NSW, Sydney
Joined Sep 2012
Is it fast or slow oscillation? If fast, lower p gain. If slow, lower I gain
jolyboy is offline Find More Posts by jolyboy
Old Feb 27, 2014, 09:09 AM
Ran D. St. Clair is offline
Find More Posts by Ran D. St. Clair
Ran D. St. Clair's Avatar
United States, CA, Sunnyvale
Joined Dec 2006
Your pitch and roll gains are going to be very different. Pitch gains will be much lower. When I say roll, I mean ailerons in airplane mode. You might call it yaw in hover mode. I assume you are using differential thrust for airplane yaw, hover roll. That will be different as well.
All of the control surface based stability and control will be weak in hover mode for that design. You lack sufficient lever arm to do much, especially in pitch.
Assuming you can get it to hover, it won't handle hardly any wind. It should be fun to play with though.
Ran D. St. Clair is offline Find More Posts by Ran D. St. Clair
Old Feb 28, 2014, 12:03 PM
Joined Jan 2011
Thanks for the help.
I can get it to hover pretty well in horizon mode with the multiwii, but the pitch and yaw are indeed a little weak. I may switch to a delta wing setup to increase the pitch control more. putting the motors and control surfaces nearer to the wing tips should help with the yaw.
The oscillations are fast, typically i can get it to oscillate by putting some gentle pressure on a control surface. I think the flexibility of the frame is increasing it.
Old Feb 28, 2014, 08:58 PM
jolyboy is offline
Joined Sep 2012
Maybe use larger elevons for better control, the ones in the photo look tiny although it is hard to see them.
Are the elevons in the airstream of the props too?
Old Mar 01, 2014, 03:52 PM
Joined Jan 2011
Yes, they are in the wash of the props. That's a good idea, I may make them a little bigger. I am also going to cut down the wing tips all the way to the elevons to lower the moment.
Old Mar 07, 2014, 12:40 AM
Joined Jan 2011
update: it flies! multiwii PID values still wonky
This is how it looks now! apparently it is called an << H Wing >> by some.
Here's what's happening: No matter what I do to the PID for pitch, it's still way too aggressive in bringing it back to level. And no matter how much I turn up the PID on roll, it still takes a few seconds to bring it back to level. Essentially, if I could switch these two behaviors, the H wing would fly perfectly. Any ideas?? Just a limitation of the code?
Also, lowering the P for pitch below 3 causes oscillations, as does increasing the P for the roll past 9. Changing I and D for roll seems to have no effect.
Currently:
P I D
Roll 9 0.25 20
Pitch 4 0.03 0
Yaw 7 0.03 0
Old Mar 07, 2014, 02:53 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Can you show us where the CG is? I would also cut those vertical stabs so they look like triangles. Too much vertical surface in front of the CG currently for yaw stability.
For your situation you may want the pitch gyro to be sensitive but constrain the servos movement range to a smaller value so it doesn't over correct. Lengthening your servo horn is one way to shorten its movement range.
If you need more roll response, scaling your roll gyro command in code will do that.
RCvertt is offline Find More Posts by RCvertt
Old Mar 07, 2014, 03:44 PM
Joined Jan 2011
The CG is roughly in the middle. It hovers with minimal adjustment.
How do I scale the gyro in the code?
I've been reluctant to change the control horns on the elevons as these also control yaw, and yaw response is aleady kind of slow.
Also, the multiwii gui lets you increase rc rate for pitch and roll, but not yaw. Looks like I need to look into the code again.
Old Mar 07, 2014, 03:58 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
CG sounds a little aft for a straight wing. Has it flown forward yet?
Old Mar 07, 2014, 10:23 PM
Joined Jan 2011
It may indeed be a little aft, I'm still trying to iron out the aggressive pitch correction before I try putting it horizontal again.
I set the control horns down some ( less throw) and it just slows down the rate of oscillation and makes it a little worse. So far no combination of P I D has managed to eliminate the overshoot.
Old Mar 07, 2014, 11:59 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Got some hover video we can look at?
Old Mar 08, 2014, 01:09 AM
Joined Jan 2011
I'll upload some video the next time I test in the day time! I usually test at night for safety.
I minimized the overshoot by *increasing* the P value for pitch. About 7 gives a nice return to horizontal in about 1 second with minimal overshoot., I and D are zero. It seems like P value is inversely proportional to response time. I can't understand this but it is handling nicely now.
Idea G.N.A.T.S., EPP VTOL Tailsitter ** FREE PLANS** leadfeather Foamies (Scratchbuilt) 90 Apr 03, 2015 02:51 AM
Build Log F-22 based VTOL tailsitter with pseudo thrust vectoring Phaedra Scratchbuilt Indoor and Micro Models 14 Jan 28, 2014 01:00 AM
Discussion Fan fold VTOL twin tailsitter Helno VTOLs 1 Jan 12, 2014 11:28 PM
Discussion Blade CX tailsitter Foamy VTOL test flight in smoke/air a9wr816t74 Foamies (Scratchbuilt) 4 Jan 15, 2011 12:12 PM
Help! tiny VTOL/Tailsitter using RC plane parts nanobot9000 VTOLs 5 Mar 04, 2010 02:08 PM
