Old Sep 09, 2013, 01:13 PM
BranoB is offline
Find More Posts by BranoB
Canada, ON, St. Marys
Joined Jul 2012
Behotec Hornet III ECU and Spectrum Telemetry
If you do not like Spectrum Radios, please keep it for yourself.
For those who are using DX18 or DX10 with Telemetry I designed and build interface module between PROJET ECU Hornet III and Spectrum Telemetry TM-1000 module. Now you can see vital data on DX 18 radio under JetCat menu, as for now, Spectrum doesn't has submenu for ProJet Hornet ECU.
Please check the video if you are interested to see how module is working.
Any constructive input is accepted. Thank you.
Here is the video:
http://www.youtube.com/watch?feature...&v=DnLONwhmQdU
Here is the video:
Spectrum Projet Telemetry (5 min 16 sec)
Here is the video from final PCB. Module is available now.
Projet Hornet III transmitting data to Spectrum DX-18 radio thru the XBUS (0 min 47 sec)
BranoB is offline Find More Posts by BranoB
Old Sep 19, 2013, 04:08 PM
BranoB is offline
Joined Jul 2012
Here are the messages as the JetCat has different messages as Projet HornetIII:
PROJET->JETCAT
OFF-> OFF
STANDBY->WAIT FOR RPM
PROP HEAT ->IGNITE
FUEL IGN -> IGNITE
BURNER ON -> IGNITE
FUEL HEAT -> IGNITE
RAMP-UP -> ACCELERATE
WAIT ACC -> ACCELERATE
SLOW Down -> SLOW DOWN
COOL Down -> SLOW DOWN
CALIBRATE -> LEARN HIGH
CAL IDLE -> LEARN LOW
Go IDLE ->STABILIZE
STEADY - STABILIZE
AUTO HC -> Speed Reg
PUMP START ->NOT USED
EMERGENCY ->NOT USED
TEMP DELAY ->NOT USED
PVolt Delay ->NOT USED
Decel Delay->NOT USED
If you think, that the assignment is incorrect please let me to know which status should be assigned differently.
Thank you.
Old Sep 20, 2013, 08:06 AM
henke is online now
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
Anything for Jeti in the works? Xicoy<->Jeti
henke is online now Find More Posts by henke
Old Sep 20, 2013, 08:21 PM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
Very cool !!! and good work.
Let me know when you get the Xicoy version done.
Dr Honda is offline Find More Posts by Dr Honda
Old Oct 06, 2013, 10:24 PM
BranoB is offline
Joined Jul 2012
I'll see about Xicoy as so far nobody around me doesn't have it.
