Old May 16, 2013, 08:40 AM
JDMCARPETS is offline
Find More Posts by JDMCARPETS
KING of PING!
JDMCARPETS's Avatar
United States, PA, Lancaster
Joined Nov 2008
Originally Posted by philfun View Post
Hello,
Need clarification about the batteries to use.
The web site propose 4500ma 4 S or 2200ma 6 S
What advantages to use either one.
The prices seems to be close.
Undecide which one to select.
Thanks for your input.
Phil
a lot of guys have 3s 2200 batteries hanging around,so you could series them to get 6s..like wise for 4s batts...if you don't have batts hanging around,i would go with 6s because of less amps..smaller esc and possibly bigger prop..
JDMCARPETS is offline Find More Posts by JDMCARPETS
Old May 16, 2013, 09:59 AM
tdab is offline
Find More Posts by tdab
LTUP = Laugh Till U Pee
tdab's Avatar
Carolina's
Joined May 2004
Originally Posted by JDMCARPETS View Post
a lot of guys have 3s 2200 batteries hanging around,so you could parallel them to get 6s..like wise for 4s batts...if you don't have batts hanging around,i would go with 6s because of less amps..smaller esc and possibly bigger prop..
Be careful guys. What you actually need is a series connector for two 3S lipos...NOT a parallel adapter.
For example on two 3s2200 Lipos:
A series connector will give you 6S2200
A parallel connector will give you 3s4400
-t
tdab is offline Find More Posts by tdab
Old May 16, 2013, 02:38 PM
Chascall is online now
Find More Posts by Chascall
Hay Pilot
Chascall's Avatar
United States, TX, Fayetteville
Joined Mar 2013
Is it OK to run two 3S batteries of different mAh, say a 2200 and a 2100 for your serial setup?
Chascall is online now Find More Posts by Chascall
Old May 16, 2013, 04:17 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Not a good idea, they should be of the same capacity and c rating. Preferably even the same brand and age.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old May 17, 2013, 12:11 AM
Hay Pilot
Chascall's Avatar
Joined Mar 2013
Thanks so much.
Old May 17, 2013, 03:55 AM
Burke, VA
Joined Sep 2009
Thanks so much.
You have to think of it like this, you are essentially turning two batteries into one and if they don't match it's like having half the cells in the battery different than the other half. On my 70" Slick I hook two batteries in series and I have them matched as close to each other as I can, then I mark them with a Sharpie so I always charge them and discharge them the same as if they were one pack. Also when I use them separately in my 60" planes as 4s I try to fly at least the same two packs down every time I fly so they have approximately the same number of cycles on them when I pair them up in the Slick again. This may be a little overboard but I figure it can't hurt to do this.
Old May 17, 2013, 07:05 AM
philfun is online now
Find More Posts by philfun
Windsor, Canada
Joined Sep 2003
Batttery
Thanks for the feedback.It really help .I just realize the motor coming from Milehigh for the 360 SLICK is working on 4s batteries maximum.So I'll get some 3300mA 4s.The next step is to find a good brand.
Any preferred brand ?
Phil
philfun is online now Find More Posts by philfun
Old May 17, 2013, 07:39 AM
kohersh is offline
Find More Posts by kohersh
PA Team Pilot
kohersh's Avatar
United States, FL, West Palm Beach
Joined Apr 2011
If your flying it with the recommended kv motor your going to want to run it on 6s hands down. Higher voltage = higher prop RPM = far better performance in 3D maneuvers.
I've flown mine on 2x 3s 2250s and just picked up 4 45C Nanotechs 6s 2650's. This is the power setup I first saw it fly on and it made me want the plane. The extra capacity is nice too
kohersh is offline Find More Posts by kohersh
Latest blog entry: 4 Sale @ Joe Nall
Old May 17, 2013, 07:46 AM
Windsor, Canada
Joined Sep 2003
battery
Ok, but the motor data don't seems to accept 6s battery.
Mike from Milehigh is recommended to stay with 4s
Old May 17, 2013, 08:13 AM
stevelmaa is offline
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Phil
I'd go with Gensace, which are probably out of stock but worth checking on. After that Id go with Glacier. I run 25c on up. Just my preference mind you.
stevelmaa is offline Find More Posts by stevelmaa
Old May 17, 2013, 11:51 AM
kohersh is offline
PA Team Pilot
kohersh's Avatar
Joined Apr 2011
Like I said, its dependent on the motor KV your running.
From mile Highs website: "MOTOR:900-1000 Watt (4250/7) 4-cell 700KV / 6-cell 500KV"
I have a 500KV motor @ 6s = approx 11,100k RPM
Sounds like you have a 700kv on 4S = approx 10,300 RPM
Old Jun 05, 2013, 12:19 PM
kohersh is offline
PA Team Pilot
kohersh's Avatar
Joined Apr 2011
Improved Gear for the Slick 360
I mentioned in a previous post that i thought the supplied wire gear was lacking to say the least, for an airplane like this. So I looked around for a better one and with a sketch and some assistance from Graph Tec chose this one, for a .46 U-Can-Do, its very very close to the dimensions of the wire gear
I think the end result looks great, the stance of the aircraft is preserved and so far all has been well with it.
Here is the bracket and plate I made to mount the new gear to.
Build Log Skywing, Winner's Model, Hokusei, 3DHS 48"-55" EPP Build & Repair Tips groovejet 3D Foamies 429 Mar 06, 2015 04:57 PM
New Product Winner's Model 37.5in Edge EPP-- Pics and videos CNJ3 3D Foamies 35 Jan 31, 2014 11:25 AM
New Product Winner's Model 48in Extra 330LX SEPP - stiff EPP plane with airfoiled tail surfaces groovejet 3D Foamies 639 Jul 07, 2013 12:45 PM
Build Log Mile High R/C Winners Model 49" EPP Yak 55m Build Thread funflyr 3D Foamies 38 Jul 12, 2012 04:33 PM
Sold NIB BH MODEL Sukhoi SU-31 55in. ARF $99 + S/H wyldkrd Aircraft - Fuel - Airplanes (FS/W) 3 Jun 11, 2012 06:37 PM
