Old Jun 10, 2012, 08:19 PM
N485TG is offline
Find More Posts by N485TG
United States, OR, Medford
Joined Nov 2011
All Control Surfaces Locked Out
I have all of my control surfaces going from my RX - OSD - Servos and at first everything is fine when you first plug in the Battery but then less than a min later everything is locked out no control what so ever. I know for sure its not my RX because I plugged a servo into the Rudder CH and it works just fine. So makes me think it might be the OSD. Anyone have any ideas? Thanks in advance.
Trevor
N485TG is offline Find More Posts by N485TG
Old Jun 10, 2012, 08:40 PM
N485TG is offline
Joined Nov 2011
Never Mind fixed it!!! After so long with the throttle off it will lock you out. Safety thing I guess.
Old Jun 10, 2012, 10:50 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
What will lock you out?
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Jun 10, 2012, 11:27 PM
N485TG is offline
Joined Nov 2011
Well found out it was the OSD not letting the signal of my input to the servos to go threw to tell the servos to move. So with the Throttle off for to long will make the OSD lock me out from moving any servos. But with the Throttle up it seems to work just fine.
Old Jun 18, 2012, 10:06 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
N5486TG, the OSD should definitely not be locking you out. Was the return to home feature enabled/triggered?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jun 20, 2012, 09:59 AM
N485TG is offline
Joined Nov 2011
NO it wasnt and I think i fixed it, I noticed when ever the throttle was down to 0% the control surfaces wouldnt work but if you gave it throttle everything would start working again. So for now i'm not plugging anything into the OSD untill I can learn the plane first. And then later down the road ill be plugging everything into the OSD. But thanks for your help anyways.
Discussion dx8 lock out or lock up issue?? help chaos2984 Radios 7 May 02, 2012 09:54 AM
Discussion Lock out with Hitec Aurora le fou Radios 7 Apr 25, 2012 07:58 PM
Help! Is there any gimbal stabilisation unit out there that can do camera lock? hexa Multirotor Talk 9 Apr 17, 2012 06:46 PM
Question Locked out of certain threads Meebo Site Suggestions / Complaints 0 Nov 17, 2011 02:17 AM
For Sale Snap-on Deluxe Lock-Out kit/Slim Jims, lock picks, wire picks, case/Serious Inquires dgfisher2004 Non R/C Items (FS/W) 6 Jan 09, 2006 05:32 AM
