Old Jul 29, 2003, 02:10 PM
soundman is offline
Find More Posts by soundman
soundman's Avatar
Norfolk, UK
Joined Jul 2002
Bob Selman actuator set up
I've recently got some of the Bob Selman actuators - what the best way of connecting these to the control surface & what sort of linkage should I be using?
I've made a couple of home brew attempts - but I'm not really happy with it yet.
Any info greatly appreciated - photo's even more so
Cheers
Soundman
soundman is offline Find More Posts by soundman
Old Jul 29, 2003, 10:10 PM
Dan Leonard is offline
Find More Posts by Dan Leonard
Dan Leonard's Avatar
Lenexa KS USA
Joined Jun 2001
Here is the way I do it. I think this is the way Bob had intended it. Use brass wire that comes with actuators for actuator end. Cut shrink tubing into 4 pcs. Make push rod out of appropriate length .020 or .030 carbon rod. I bend a piece of .020 piano wire for control surface end just like the brass .020 wire. slide pieces together and shrink. You don't have to use any adhesive if you don't want to the friction will hold it fine. I use the Dubro micro control horns and then cut them down to the first hole. Then drill new .020 hole just behind it.
Dan Leonard is offline Find More Posts by Dan Leonard
Old Jul 29, 2003, 10:12 PM
Lenexa KS USA
Joined Jun 2001
other end
Old Jul 29, 2003, 11:03 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
Here's an alternative to the 'other end'. I make a figure '4' out of guitar string (~.014" works fine), and attach it with the same heat shrink as Dan mentioned. The difference is that you can pop the keeper over the horn and remove the 90* bend from the hole so you can take them off, or more importantly, put them on after the surfaces are glued in place. Sorry the picture isn't sharper...
Mike Taylor is offline Find More Posts by Mike Taylor
Old Jul 30, 2003, 04:12 AM
soundman is offline
soundman's Avatar
Norfolk, UK
Joined Jul 2002
Thanks guys, that's a little easier than how I've been doing it
With the heatshrink used to join the links, are you able to slide them through the heat shrink to adjust the length?
Thanks again
Soundman
Old Jul 30, 2003, 11:56 AM
Team 30 Micro EDF
Joined Apr 2002
Yes, even after you shrink the tubing, it is possible to slide the components around. Once you have found the correct length, a touch of CA locks it all down permanently.
Bob Selman Act. Hook-up Taniwha314 Scratchbuilt Indoor and Micro Models 2 May 16, 2003 11:41 AM
Bob Selman 2g Actuator Vs DWE 1 g fritts Scratchbuilt Indoor and Micro Models 2 Jan 22, 2003 07:17 AM
WTB: Bob Selman Actuator flytowner Aircraft - Electric - Airplanes (FS/W) 3 Jan 11, 2003 02:04 PM
Does anybody have an extra Bob Selman actuator they want to sell me? flytowner Scratchbuilt Indoor and Micro Models 6 Jan 11, 2003 02:03 PM
HELP! I spilled a huge amount of CA on my brand new Bob Selman actuator!!! :( flytowner Scratchbuilt Indoor and Micro Models 8 Jan 09, 2003 12:04 AM
