Old Jan 21, 2010, 10:57 AM
roper is offline
Find More Posts by roper
Bremerton, WA
Joined Jan 2010
Thunder AC6???
Thinking of buying the Thunder AC6 anything I should know about bit?? Also will this balance my parkzone batt's. I know that I have to get a banana ec3 adapter. Just wondering about the balance lead.
roper is offline Find More Posts by roper
Old Jan 22, 2010, 12:34 PM
roper is offline
Bremerton, WA
Joined Jan 2010
no takers????
Old Jan 22, 2010, 01:20 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Can't fight the addiction!
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
lol.
Sometimes people here wish for new people to do some research on their own prior to giving them information. There are alot of "sticky" threads at the very top of each forum that address the most common answers that are asked.
Since you are a fellow WA resident, here is your answer.
Given that your parkzone lipo's use the JST-XH balance connector, you will find that a GREAT many different balance/chargers use this as a standard connector, or a standard supplied 'board' in cases where they use a dongle arrangement.
The Hobbypartz Thunder AC6 uses this dongle/board arrangement and comes supplied with an JST-XH balance board, so you are good to go.
As you purchase other lipo's that use different balance taps, such as thunderpower and hyperion, you will just need to purchase different boards, which usually range from $4 to 6 bucks depending on where you buy it.
Do yourself a favor, don't buy any more Parkzone batteries. You'd do far better to save the coin and buy other less expensive brands.
Also, ditch the EC3 connectors. Use a deans or perhaps the newer XT60 connectors. Those are great.
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Jan 22, 2010, 02:54 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
In my short experience with it the AC6 is impressive.
4*60 is offline Find More Posts by 4*60
Old Jan 22, 2010, 04:48 PM
Mike in Fresno is offline
Find More Posts by Mike in Fresno
opinions/advice given
Fresno,CA
Joined Dec 2003
just got mine and used the balance block with the stock balance tap from the PZ battery. Had to buy a jumper to do my TP batts. Easy to use charger. Took 60 mins to balance charge the 1300ma PZ battery at pre-set .9amp.
Mike in Fresno is offline Find More Posts by Mike in Fresno
Old Jan 22, 2010, 11:56 PM
Stins is offline
Find More Posts by Stins
Stins's Avatar
USA, PA, New Castle
Joined Jan 2009
I have had mine since Oct. no problems and I've used it on every kind of battery. A more extensive manual is found here... http://www.hota-exp.com/product_info...2d5m20c0cbnah7
Hope this helps.
Stins is offline Find More Posts by Stins
Old Jan 23, 2010, 02:57 PM
garyji is offline
Find More Posts by garyji
AMA #937780
garyji's Avatar
Forrest City, NC
Joined Feb 2009
I've got two of them and they are great.
G.
garyji is offline Find More Posts by garyji
Discussion Thunder AC6 compatible Lipos Endersgame75 Batteries and Chargers 5 Feb 24, 2010 11:21 PM
Question Can Thunder AC6 Charger charge Lead Calcium or Gel Cell? claycephus Batteries and Chargers 3 Jan 18, 2010 02:30 PM
Discussion thunder ac6 wzak29 Mini Helis 6 Jan 14, 2010 09:41 AM
Question Can Thunder AC6 Charger charge Lead Calcium or Gel Cell? claycephus HobbyPartz.com 2 Jan 13, 2010 05:55 PM
Discussion thunder ac6 and ge ac6 is there a difference? nigel6666 Batteries and Chargers 1 May 08, 2009 07:54 AM
