Old Feb 27, 2012, 12:49 PM
Bahamas Michael is offline
Find More Posts by Bahamas Michael
The Bahamas, City of Freeport, Freeport
Joined Feb 2012
Hey Folks,
Just been browsing the site and joined, looks like the place to be, hello to all.
This weekend a friend of mine gave me two Axe CPv3 with tons of spare parts. He said he going back to his planes....needless to say I was very happy, except that the Heli doesn't fly..believe it is a problem with the 3n1 board.
The unit is fully charged / all four batteries / lucky me !
All servos function and move well, the gyro goes through it stabilization bit and then green has a green light, but main motor doesn't turn. Tried the spare 5 channel controller and the main motor off of the other Heli.....same thing, motor will act like it is going to move and does so sporadically...like a bad connection (which I have checked) or bad ESC...
So here is what I would like your expert advice on.
1. what ESC / Gyro combination should I put in Heli-Max CPv3 that will still work with the stock 5 channel receiver and not increase MAUW to drastically.
2. do I have to change out the servos, I have like 3 spare of each one.....
3. can I cost consciously add the required components now so it will fly, while keeping in mind the BLDC motors / LiPo batteries in the future.
4. any recommendations or links appreciated, ebay has the stock E board CP for $84.99 so thats my budget range.
Thanks, looking forward to becoming a Heli flyer
Bahamas Michael
Bahamas Michael is offline Find More Posts by Bahamas Michael
Old Feb 27, 2012, 09:17 PM
rrg is offline
rrg
Find More Posts by rrg
rrg
rrg's Avatar
USA, KY, Edgewood
Joined Dec 2007
Sold my two. Still have some parts left i think....
rrg is offline Find More Posts by rrg
Old Feb 29, 2012, 08:13 AM
Joined Feb 2012
rrg, do you have any e boards?
Old Feb 29, 2012, 11:27 AM
rcwings is offline
Find More Posts by rcwings
North Simcoe Flyers
rcwings's Avatar
Midland, Ontario, Canada
Joined May 2007
BM,
You may want to consider replacing the e-board with a couple new brushed speed controllers and a gyro. Will take a little tinkering if you are up to the light task, but will work much better and will be cheaper too.
That is what I did when mine blew as could not justify paying the amount they want for that unit. Fortunately I had the ESC's in my parts bin, but they are pretty inexpensive to buy.
Marko
rcwings is offline Find More Posts by rcwings
Old Feb 29, 2012, 06:05 PM
rrg is offline
rrg
rrg
rrg's Avatar
USA, KY, Edgewood
Joined Dec 2007
Sorry man but no i dont.....
Old Mar 03, 2012, 04:34 PM
FNFAL is online now
Find More Posts by FNFAL
See the Fur Fly
FNFAL's Avatar
Dayton, OH
Joined Oct 2006
Well after a few flights, I have to say that the little Axe CP is growing on me. The head seems to be loosening up, and the stability is improving - especially when out of the rotor wash ground affect. It's all stock, but I did clean-up the wiring a little and ditched the foam pad and zip ties for the control board and went with some RTV silicone to mount.
She gets around OK outside, but she's no power house. Don't get me wrong - she has plenty of power to tool-around and do a few little tricks, but I say this because any wind over 10mph can potentially sweep her away before you know it.
The main plastic mast seems a little curved and causes a little wobble as seen at the top head button, but thankfully it straightens out at the blades. A replacement mast showed the same defect.
I do not reccommend this heli for a beginner because the tail is a little loose and can be a distraction for them, but for an intermediate pilot, it's sufficient and actually is quite fun to fly in a park-flyer sense.
The manual warns against spending too much time dialing in the gyro and I agree. There's not much adjustability, but a little tinkering has allowed me to get a somewhat consistent response from beginning to end. But the occasional tail kick is unavoidable.
Where this bird finds it's place is for those learning to get more comfortable with normal and inverted flight, but don't want to risk the TREX 450.
Parts are plentiful too, as the V4 shares many of the same parts with its predecessor and almost any local hobby store will have a few bits laying around.
IMHO this bird is ment to stay cheap and as-is. Upgrading is not at all cost effective - cause by the time you add it up, you could get yourself something with a nicer plateform in the heli classifieds. And what they want for the factory metal upgrades is absolutely rediculous. MicroHeli does however still make an all metal top-end for about $150 for those who are interested - but I won't be getting them...ha.
FNFAL is online now Find More Posts by FNFAL
Old Mar 15, 2012, 05:43 PM
FNFAL is online now
See the Fur Fly
FNFAL's Avatar
Dayton, OH
Joined Oct 2006
Well, after a handful of flights, for no reason, the 2.4ghz radio system is no longer working. It appears to be either the Rx or the TX. And while the TX LED light does come on most times when the switch is turned on, the Rx LED does not at all. Either way, it's hard to tell.
I've got two emails into Hobbico/Heli-Max but no answer yet. I'm toying with the idea of using a futaba R6106HF.
Old Mar 15, 2012, 07:27 PM
fpainter3 is offline
Find More Posts by fpainter3
fpainter3's Avatar
USA, KY, Florence
Joined Aug 2007
maybe the Rx lost its bind. there should be a procedure to rebind it in the manual
fpainter3 is offline Find More Posts by fpainter3
Old Mar 15, 2012, 08:01 PM
FNFAL is online now
See the Fur Fly
FNFAL's Avatar
Dayton, OH
Joined Oct 2006
Thanks, I kinda suspected that too. Upon seeing your post, indeed the rx has some sort of bind button. There is no mention of it in the manual and it's not marked as such. When I push it, and go through what I find is a normal bind proceedure for other makes, it just flashes red at me...hmm..
Rx and TX sent off to inspection & repair per Lennie.
Old Mar 22, 2012, 08:37 PM
FNFAL is online now
See the Fur Fly
FNFAL's Avatar
Dayton, OH
Joined Oct 2006
While the stock radio is being fixed (Hobbico was nice enough to send me email confirm of receipt), I decided to use a Futaba. Initial results are very positive.
Although the new 2.4 is glitch free and is satisfactory when it's working, I find the Futaba upgrade wonderful. Now the servos has much more resolution, are not notchy, and input delay is greatly reduced.
All this adds up to significantly more precision when flying in tight quarters like indoors. The tail gyro is still a little nervous, but now that I don't have to anticipate my next cyclic correction, I have more focus on things like the tail.
SO, if you have a spare rx laying around, you may want to try it out too.
UPDATE: OK, now the gyro driver is screwy. It runs full-blast all the time. Just started with no reason. So now I got to send the board back too. Ugh!
Old Mar 30, 2012, 12:15 PM
k4pacific is offline
Find More Posts by k4pacific
AMA 988154
k4pacific's Avatar
United States, NJ, Somerset
Joined Jan 2009
Replacement Lipo Battery
Hi All: This is my first post on AXE CP thread. I am awaiting delivery of the AXE and was wondering what batteries are being used to replace the supplied lipo? I would like to use one with a higher C rating. I think the stock battery is C15 not sure?
I look forward to future posts. The AXE CP is my first CP heli, been flying a Hirobo Quark SRB.
k4pacific is offline Find More Posts by k4pacific
Old Mar 31, 2012, 09:10 AM
douglas4 is offline
Find More Posts by douglas4
"If it ain't broke,fly again"
douglas4's Avatar
Canada, ON, Greater Sudbury
Joined Aug 2006
Why don't you just replace it with either the blade cp pro 2, 2 in 1 and use a separate gyro. The blade SR 2 in 1 works too.
douglas
douglas4 is offline Find More Posts by douglas4
Old Mar 31, 2012, 01:26 PM
FNFAL is online now
See the Fur Fly
FNFAL's Avatar
Dayton, OH
Joined Oct 2006
That's a good idea. Will explore it. Thanks.
douglas
Old Apr 01, 2012, 08:19 AM
johrich is offline
Find More Posts by johrich
johrich's Avatar
United States, GA, Kathleen
Joined Dec 2007
I have not posted anything in this forum for years, but I had to chime in. I learned to fly helis using the old Helimax CP-L (the L stood for Lipo). In the old CP-L manual, which I have attached, it describes how to install a separate gyro (the Futaba GY240), and a separate tail motor ESC in place of the ones on "e board" of the AXE. I later actually removed all the original Helimax electronics, both the eboard and the receiver, and put in a Spektrum receiver and a separate Great Planes ESC for the main motor. It actually flew much better with the changes and I flew the AXE for several years with these modifications. I still have it, though I pulled out the receiver for another project. I also later replaced the GY240 (which I needed for another helicopter) with a Telebee gyro and later and Eflite gyro. I don't know how much difference there is between my old Axe and the new one, but the attached manual may help you figure out what to do on the new AXE CP.
johrich
johrich is offline Find More Posts by johrich
Old Apr 01, 2012, 12:24 PM
FNFAL is online now
See the Fur Fly
FNFAL's Avatar
Dayton, OH
Joined Oct 2006
Thanks. I'm not sure why HeliMax removed this info from the current version. Perhaps they think it's all better now. But clearly with my most recent experience, it's a valuable another option.
Discussion The Official Helimax Axe EZ Thread BIGDANO Coaxial Helicopters 22 Sep 12, 2009 01:31 PM
I love Planks Post em here Flymerc Flying Wings 55 Feb 17, 2008 04:25 PM
My Girlfriend's GWS Beaver Build Thread (With Pics) nitroaddict Parkflyers 84 Aug 11, 2007 10:51 AM
Tiger Moth Paint jobs: post em' here. Ozprey GWS (Grand Wing Servo) 73 May 01, 2004 06:31 AM
Pictures of your fleet, post 'em here Paul Susbauer Parkflyers 69 Mar 07, 2003 09:38 PM
