Old Feb 28, 2005, 07:30 PM
glofuel is offline
Find More Posts by glofuel
I'd Rather be Flying
United Kingdom, Milton Keynes
Joined Feb 2005
Help!
kc spreadsheet power question
does anybody know how the mechanical power delivered by the rotor in the spreadsheet eg using tango 45-07 10S2P pack is calculated
glofuel is offline Find More Posts by glofuel
Old Feb 28, 2005, 11:49 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
all the equations are available on the spreadsheet.
askman is offline Find More Posts by askman
Old Mar 01, 2005, 02:56 PM
glofuel is offline
Joined Feb 2005
thanks for answering my question, have seen the formula's but my math is not too good when using formula's. I know it is a simple case of ohm's law so am I right in saying to calculate the maximum power available is the batt pack power plus motor power in watts. ie batt capacity x voltage plus motor power in watts together ? or am I going down the wrong road.
Also how do I calculate hover, average and max power. I have been working on the basis that 750W is approx 1H.P in i.c terms and taking it from there.
Any feedback would be much appreciated
Old Mar 01, 2005, 03:10 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
in KC's spreasheet, average/hover/peak power is defined in the sheet as watt/lb. so, if you want 100 watt/lb setup, you use 100*weight(in lb)/efficientcy to find power needed. the complicated part is due to resistance of different component(motor/battery/etc) that will affect your efficientcy.
I use about 80% efficientcy if it is not critical, but KC's sheet calculates it based on available motor and battery data. Lets say you have 5lb heli(ready to fly) and you want 100 watt/lb power. this means you need to be able to provide 5*100/.8= 625watt. using 6S setup(which give about 20v), you will need 31amp current draw.
Old Mar 01, 2005, 03:24 PM
glofuel is offline
Joined Feb 2005
Thanks Askman, I will have a play and see if it makes sensce now
FAQ KC's Power System Spreadsheet - Version 5.0 K.C. Electric Heli Talk 214 Oct 03, 2011 07:23 PM
KC's Power System Comparison Spreadsheet - Part 2 K.C. Electric Heli Talk 159 Jan 20, 2007 08:02 AM
Discussion Mutant Logo 10 and KC XLS Power Question Vertical Electric Heli Talk 18 Jun 03, 2006 05:25 PM
KC spreadsheet question rotaryguy Electric Heli Talk 9 Oct 04, 2005 08:14 PM
Question Openoffice and KC's Power System SpreadSheet John_C Electric Heli Talk 1 Jan 29, 2005 12:55 PM
