Old Mar 08, 2015, 04:07 PM
YurSoTall is offline
Find More Posts by YurSoTall
United States, OH, Reynoldsburg
Joined Feb 2015
Help!
OPTO ESC and Overcraft PDB batch 4 installation question
Can someone please provide a picture or clearer instructions as to where I should be soldering wire from #1 esc to 5v regulator? I am not sure which spot on the board I need to hook this up since I am using 12A OPTO's and do not know how to hook it up to the board. Just looking for a simple wiring diagram for the board utilizing opto's. It is not very clear about the jumpere wire as well. I have searched everywhere and cannot find anything. I am new to this stuff and dont want to fry the controller. The info I read from the tutorial below does not specify what 5v pad or where it is located.
The "bec" pad uses the bec from your ESC #1. If you are running OPTO ESC, you probably need to use the onboard 5v regulator. In this case, instead of place your posstivive wire from the "BEC"pad, use the 5V marked on the board. Other way could be use a wire jumper from the 5V to the bec (at the bottom of the boards), and from the "BEC" to your FC.
YurSoTall is offline Find More Posts by YurSoTall
Old Mar 12, 2015, 12:04 PM
Mattmax is offline
Find More Posts by Mattmax
Germany
Joined Jun 2013
look here: PDB batch 4 - 2015, for ZMR 250 - Mystery
Mattmax is offline Find More Posts by Mattmax
Sold overcraft PDB batch 3 scottvar Aircraft - Electric - Multirotor (FS/W) 2 Mar 05, 2015 06:12 PM
Sold ZMR250 Overcraft PDB (Batch 3) CE37 Aircraft - Electric - Multirotor (FS/W) 9 Mar 04, 2015 12:55 PM
Sold Overcraft Batch 3 PDB loosenut Aircraft - Electric - Multirotor (FS/W) 2 Feb 26, 2015 03:19 PM
Help! Overcraft (batch 2) PDB and LC Filter SubEclipse FPV Talk 2 Jan 27, 2015 07:11 PM
Sold OverCraft ZMR PDB board - V1.1 (Batch 2) - 2 dead LEDs Schtubb Aircraft - Electric - Multirotor (FS/W) 3 Jan 21, 2015 11:09 AM
