Old Jan 09, 2002, 03:41 PM
cruzomatic is offline
Find More Posts by cruzomatic
San Antonio, Texas USA
Joined Feb 2001
How do I remove epoxy from balsa?
I went a little overboard with the epoxy on some balsa. Is there anyway to remove it?
cruzomatic is offline Find More Posts by cruzomatic
Old Jan 09, 2002, 06:10 PM
Ron Cichowski is offline
Find More Posts by Ron Cichowski
Old Guy
Ron Cichowski's Avatar
Carver, MA USA
Joined Jun 2000
#40 Grit Open Coat sandpaper on an 8" disk grinder ought to do it.
Ron
Ron Cichowski is offline Find More Posts by Ron Cichowski
Old Jan 09, 2002, 07:32 PM
sanjoh is offline
Find More Posts by sanjoh
Master Crasher
sanjoh's Avatar
Sunrise, FL
Joined Nov 2001
How bout some new balsa.
sanjoh is offline Find More Posts by sanjoh
Old Jan 09, 2002, 10:25 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
OOPs, epoxy is forever.
If its just one lump, you might try prying it off. It will take some wood with it, and need refinishing. Nothing will dissolve it.
A Dremel tool with a sanding drum will be better than the 8" grinding wheel but it will still be ugly.
Heating it with a soldering iron will soften it and may allow removal. Use a 15W or so, not something that chars the wood.
I don't think a covering iron will get hot enough to soften it, but I may be wrong.
Dave
DaveW is offline Find More Posts by DaveW
Old Jan 09, 2002, 10:27 PM
Norm is offline
Find More Posts by Norm
Oak Harbor, Washington, United States
Joined Jan 2001
I've often removed epoxy by applying heat, like from a heat gun. It softens the epoxy and usually it can be pealed off the wood.
Norm
Norm is offline Find More Posts by Norm
Old Jan 10, 2002, 08:41 AM
Joined Feb 2001
Thanks, I'll give it a try
Discussion How do ya remove paint from balsa? Tailgunner1 The Builders Workshop 8 Apr 04, 2007 08:03 PM
Discussion How do I REMOVE a pod from a tailboom? soholingo Hand Launch 9 Mar 22, 2007 10:30 AM
Discussion How do i remove the Shaft from the Main gear on Blade CP? JStory Micro Helis 7 Apr 20, 2006 09:19 PM
How do I remove gear from Speed 400 motor shaft? p-zag Parkflyers 15 Aug 17, 2002 09:32 PM
How do I remove gear from Speed 400 motor shaft? p-zag Sport Planes 2 Jan 26, 2002 09:26 PM
