Old Jan 19, 2015, 06:08 PM
darticus is offline
Find More Posts by darticus
United States, NJ, Sparta Township
Joined Mar 2007
UMX Yak 54 180 BNF TELEMETRY???
I don't know about this but after binding the yak 54 mini to the DX6 New version it shows 3 screens when the set wheel is turned when set on this plane. Here are some pics of the 3 screens that come up. Other planes in this radio don't show these screens so why is it showing now? HH doesn't seem to know the answer but maybe their techs will know something if I ever connect with them. Anyone know the answer for this and what the 3 screens are for? Thanks Ron
darticus is offline Find More Posts by darticus
Old Jan 19, 2015, 08:08 PM
Julezwatts is online now
Find More Posts by Julezwatts
WOT and going nowhere
United States, VA, Charlottesville
Joined Aug 2014
The telemetry screen is standard display for most telemetry-ready TX's. It doesn't mean that the model itself supports telemetry, it's just part of the default display setting.
Julezwatts is online now Find More Posts by Julezwatts
Old Jan 20, 2015, 04:57 AM
darticus is offline
Joined Mar 2007
Can it be used? Ron
Old Jan 20, 2015, 07:38 AM
Joined Aug 2014
Originally Posted by darticus View Post
Can it be used? Ron
Not using the stock board on the Yak.
Old Jan 20, 2015, 08:26 AM
vlad_vy is offline
Find More Posts by vlad_vy
Joined Dec 2011
Most likely 'Flight Log' will work at micro planes with DSMX Rx, but nothing else.
vlad_vy is offline Find More Posts by vlad_vy
Old Jan 20, 2015, 10:30 AM
darticus is offline
Joined Mar 2007
Thanks all just never did see this before but this is a first time newer receiver plane so maybe all new plane receivers have this. Thanks Ron
Old Jan 20, 2015, 12:24 PM
microheli is offline
Find More Posts by microheli
microheli's Avatar
Joined Jul 2006
The AS3X bricks support frameloss (F) and holds (H) telemetry.
microheli is offline Find More Posts by microheli
Old Jan 20, 2015, 12:27 PM
Joined Aug 2014
But I don't think any spektrum telemetry systems are actually compatible with the micro bricks... are they?
Old Jan 20, 2015, 12:48 PM
microheli's Avatar
Joined Jul 2006
You get the frameloss and hold values from the brick to the TX usefull for range check or for any problems with the RF-Link.
For other values/sensors you need the TM1000/TM1100 modul which can not connected to the brick and is also to heavy for micros. Some newer bigger rx have build-in telemetry but also to heavy for micro planes.
Old Jan 20, 2015, 01:13 PM
darticus is offline
Joined Mar 2007
Is this just something that must be in the receiver but really not useable? Thanks Ron
Old Jan 20, 2015, 01:56 PM
microheli's Avatar
Joined Jul 2006
Frameloss and holds are usable and more is not in the receiver.
I forget there is also the telemetry link signal strength with the "lines" on the left upper corner of the display.
Old Jan 29, 2015, 01:00 PM
bhoov128 is offline
Find More Posts by bhoov128
John 20:1-18
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
yes, frame drops, holds, and rssi... that's all you're gonna get from an AS64xx brick. But as microheli pointed out, it'll assist you in knowing how your radio link is looking after a flight at whatever field you're flying.
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Jan 29, 2015, 02:18 PM
darticus is offline
Joined Mar 2007
Maybe I'll check this section after a flight and see what has been added to the screens. Thanks Ron
Old Apr 18, 2015, 11:44 AM
mutski is online now
Find More Posts by mutski
mutski
United States, AK
Joined Jan 2011
If they could get the UMX receivers to send back battery voltage, I'd buy a new controller to see it!
mutski is online now Find More Posts by mutski
Sold UMX Yak 54 180 BNF HugoCraft Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Aug 31, 2014 01:48 PM
Sold UMX Yak 54 180 BNF $100 OBO! BrendanH Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Jul 07, 2014 12:43 AM
For Sale UMX Yak 54 180 BNF $100 OBO! BrendanH Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jul 05, 2014 12:54 PM
Sold (Reduced, AGAIN) UMX Yak 54 180 AS3X BNF KenSue Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Apr 01, 2014 09:48 PM
Sold BNF UMX Yak 54 180 Sixinarow Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Nov 20, 2013 12:33 PM
