Old Aug 14, 2014, 05:01 PM
George Shering is offline
Find More Posts by George Shering
Scotland
Joined May 2005
Android apps for Unilog 1 and Unilog 2
New versions of the Android apps for Unilog 1, U1 version 2.2, and Unilog 2, U2 version 1.3, are now available for download on www.f5b.co.uk under Equipment/Limiters.
A bug fix for the single tap summary display when the screen is not filled.
The main improvement is direct activation from email attachments and files.
Unfortunately you can't post these files on rcgroups as Unilog 1 files are .uni which is not an allowed file type, and Unilog 2 files which are .txt are too big! Too bad.
George Shering is offline Find More Posts by George Shering
Old Aug 15, 2014, 11:54 AM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
George, thank you.
Both the U1 and U2 app seem to work fine on my jelly bean 4.2.2 device. It is a Pipo T1 and for the price I am relatively happy with it.
Maybe after Turnau we can add the prop AoA function and Cumulative drive efficiency?
jjmouris is offline Find More Posts by jjmouris
Old Aug 15, 2014, 03:48 PM
Scotland
Joined May 2005
Originally Posted by jjmouris View Post
George, thank you.
No problem Joe.
You provide the algorithm and I'll code it in.
Speed sensor required of course. Not many people have that.
RPM sensor is also not often available. The latest Castles have one on the white connector, good for them. Maybe we should have a white connector on your new ESC.
Old Jan 30, 2015, 11:18 AM
Scotland
Joined May 2005
New versions of the U1 and U2 android apps for Unilog 1 and Unilog 2 are available on the UK F5B website:
http://www.f5b.co.uk/unif5b-app-and-program.html
They are dated 29 Jan 2015. My apologies for a bug in the previous versions which caused a crash when the Unilog settings were changed by a device with a non English keyboard. My thanks to Andreas Lindner of F1Q for helping locate and fix this problem. If you have been trying to use the app on a non English keyboard device and have given up, please try again. A new F1Q button has been added to the options.
A new flight summary has been added to give immediate access to the most important flight details. The climb summary is now under Climb details. The voltage scale is more appropriate for 10S. In U2 the File metadata button gives more detail of the recording including the Autostart settings and Limiter settings which were used for the recording.
Please let me know if you have any problems or suggestions.
Discussion Unilog apps for Android George Shering High Performance 8 Apr 10, 2014 05:20 AM
Discussion Unilog 1 app for Android George Shering High Performance 1 Feb 02, 2014 06:15 AM
Discussion Unilog 2 app for Android George Shering High Performance 22 Jan 16, 2014 02:23 PM
Question HK Doppler App for Android matiac Electric Plane Talk 3 Nov 17, 2013 05:18 AM
New Product [Moved] Android battery management app for only $1.99! RCBatteryLog Hot Online Deals 0 Apr 23, 2011 01:38 PM
