Old Mar 07, 2014, 06:47 PM
Al M is online now
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
You are not going to twist anything on an Astro. New Creations RC might still have some Pasquito motor mounts left. Give Kirk a call. He is more of a phone person than an internet person and is very helpful and an expert on Astro's.
Al M is online now Find More Posts by Al M
Old Mar 08, 2014, 06:48 AM
Ken Myers is online now
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
Here is a link on mounting brushed motors in Keith Shaw's talk to the EMFSO.
http://www.theampeer.org/shaw/SHAW4.PDF
Scroll to the second page. Lots of information.
Ken Myers is online now Find More Posts by Ken Myers
Old Mar 08, 2014, 02:59 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
Originally Posted by Dr Kiwi View Post
Not saying I know anything about these motors , but whoa, that is a hellishly high Io isn't it? I'm also surprised by the efficiency curve.. if you look at efficiency curves in DriveCalc most motors peak at perhaps 20% of max amps... this one is >50%.
Usually what I notice in Drive Calc is efficiency maxes at about 80% of the no-load rpm, which looks nominally what this motor is doing. The efficiency at this point is just below 80% (~75% I think). I guess the high Io is due to the iron core of the motor, I have no idea how thin those stampings were. There may be more drag due to the brushes or even the gearbox, so I'm not sure how Io was measured/calculated and if it includes that drag or not.
I think max power depends on a lot of design issues. This Astro uses Samarium-Cobalt magnets that can take a lot of heat compared to the current Neodymium magnets. And in addition, the armature, with the wiring is spinning here, and so the copper may be benefiting from some indirect cooling. In other words, these old motors could likely withstand more heat than out current ones.
These are just guesses of course.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Mar 08, 2014, 03:10 PM
jollyroger is offline
Find More Posts by jollyroger
Central Lake, Michigan
Joined Dec 2002
ken would probably shake his head if I mentioned I've run Astro 25G past 700watts.
But then I won't ever mention it.
Now let's see if I can get that much out of my FAI 15G...
jollyroger is offline Find More Posts by jollyroger
Old Mar 09, 2014, 01:27 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I think that these motors were intended for quick climb and shutdown for a certain FAI powered glider competition. Not sure how good they are with a 2-cell lipo pack to keep temperature/amp draw down. I am using an old Astro 25 brushed geared motor in my Sig 1/6 Scale Cub on two 3S 2200mah lipos in series. Speed control is old "dumb"Astro 211 with help from a Li-Saver and a UBEC. APC 11x5.5 prop works well. Mount is Pasquito tubular aluminum mount bought long ago from Kurt at New Creations RC.
Also have an FAI brushed 15 that I've never used, designed for powered glider competition as above. might be OK on 2 cells with large prop for slow flying scale models.
E-Challenged is offline Find More Posts by E-Challenged
Old Mar 09, 2014, 02:33 PM
Louierc is offline
Find More Posts by Louierc
Just Plane Nuts
Louierc's Avatar
USA, NC, Southern Pines
Joined Dec 2008
I may put this geared 05 into a 72" Buzzard Bombshell old timer on 2S with a 14x5 or something like that. Needs lots of cooling, so it will be in open air.
Louierc is offline Find More Posts by Louierc
Old Mar 10, 2014, 05:09 PM
Joined Dec 2002
The motors are a lot tougher than advertised. Astro Bob is always conservative with his motor ratings. Like I mentioned before about running the 25G way past 700 watts in an LT-40. Didn't hurt the motor one bit. I don't remember how many round cells I used...either 12 or 16.
An 05 in the Bombshell sounds like a great combination. Those old FF planes makes great conversions anyway. I'd like to do a 100" Dallaire Sportster with the 25G and 4S.
There's something about those old timers, ..... graceful flyers.
cheers.
Old Mar 10, 2014, 05:55 PM
Louierc is offline
Just Plane Nuts
Louierc's Avatar
Joined Dec 2008
Jolly - the old timers are wonderful floaters and will thermal on a good day! I have a 108" Dallaire, a 84" Comet Interceptor, a Boehle Giant (16ft span), all with Hacker motors. The bigger planes run on 6S. A 84" Quaker awaits a new motor and the Buzzard may be the right size for the Astro. I see that I can get a 2S6000 pack for a modest cost. I like doing these electric conversions of old timers.
Old Mar 11, 2014, 09:02 PM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
Cobalt magnets are tested safe to 600 C !! (currie point) conservatively rated too. I've seen claims of 800 C
But that seems scary high.
Assuming that Astrobob used Decent wire with hi temp insulation /coatings.. Very likely.
(Unlike the congealed Duck Soup used as varnish on Chinese wire)
Venerable Astros would likely melt before they stopped being motors.
Bare is online now Find More Posts by Bare
Old Mar 12, 2014, 06:13 AM
davecee is offline
Find More Posts by davecee
I'd rather be Flying
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
I overheated (operator error) an Astro 25 SF geared, and a magnet or two came loose. The motor got sizzling hot You could smell the cooked odor. The motor still worked after that.
davecee is offline Find More Posts by davecee
Old Mar 12, 2014, 11:39 AM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
That's all fine and well, but even if the motor can withstand the heat, why would you want to use half of your battery energy generating heat?
Larry
Lnagel is offline Find More Posts by Lnagel
Old Mar 12, 2014, 11:50 AM
Louierc is offline
Just Plane Nuts
Louierc's Avatar
Joined Dec 2008
Haha, the answer I usually get is 'because we can ! '
Always happens when I ask - why put a bigger motor, bigger ESC and bigger LiPO in a great flying plane ?
Old Mar 12, 2014, 09:02 PM
Bare is online now
Canada
Joined Nov 2000
Fair enough.
But AstroBob produced 'quality product' :-)
Compare his products ...with the current cheap crap out of Shengzen
Twenty years on and it's still competitive :-)
Despite the perceived obsolete Brushed technology
Check out the efficiency charts on the venerable Astro Cobalts..
They don't give up much at all.
Competent engineering, components and Mfg care produced lasting result.
Old ...even brushed in the case of Astros..... Does Not mean substandard or inefficient.
Old Mar 13, 2014, 06:50 AM
Al M is online now
Wallingford, Ct
Joined Sep 2001
His brushless motors do the job also.
For Sale Astro Flight brushed FAI Racing 05 motor+ speed controll Jackspt28 Aircraft - Electric - Power Systems (FS/W) 1 Jun 04, 2011 08:29 AM
For Sale Astro 05 FAI Racing Motor Csessa Aircraft - Electric - Power Systems (FS/W) 5 Sep 20, 2010 08:31 AM
Sold **SOLD***Astro 05 FAI racing motor USED FredM Aircraft - Electric - Power Systems (FS/W) 1 Dec 06, 2009 10:57 AM
Sold Astro 05 Brushed FAI Racing with gearbox - $20 shipped Jeff_Berg Aircraft - Electric - Power Systems (FS/W) 2 Nov 09, 2008 12:49 PM
For Sale Astro FAI 05 racing motor Nobert Aircraft - Electric - Airplanes (FS/W) 2 Jun 21, 2005 08:28 AM
