Old Feb 26, 2004, 02:29 PM
quailbird is offline
Find More Posts by quailbird
quailbird's Avatar
Rich Hill Missouri 64779
Joined Nov 2003
Need some help, "Gear drives"
I've notice on the B2 stealth the motor is a geared motor and it goes fast. I built a dealta wing and I was wondering about a gear drive for a 400 motor. Does the gear drives give you more speed or thust. Can you use a gear drive to lift a heavier plane? Is a 3:1 faster than a 1:3? Do you use a smaller prop for higher speed and a larger prop for a slower motor?
quailbird is offline Find More Posts by quailbird
Old Feb 26, 2004, 02:51 PM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
I suggest getting a copy of Motocalc and playing with some numbers. The trouble is that the answer to all of your questions is... "It depends". All of the things you are asking about are affected by the particular combination of motor, battery voltage and propeller as well as the gear ratio.
Typically people use geared motors and larger props to get more carrying capacity or better climb rates but not necessarily higher top speeds. OTOH some of the fastest planes around also use geared drives. Sorry, but there are no simple answers.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Feb 26, 2004, 06:57 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
The reduction drives are strictly for getting more pulling power for climbing with heavier models. They do not make the model fly faster in any way. In fact they do quite the opposite. The are generally suitable for slower models. Note that all the racers use direct drive motors. That's because to go fast you need to turn the props fast.
You might think that you could use a gear box and turn a very high pitch prop and technically I suppose it would work but that ignores the problems of the prop being stalled. And even with higher pitch props to achieve high speeds the RPM the props have to turn is often beyond many of the motor and reduction gear boxes.
You also ask why gearing UP is not used. I suspect that is because gears introduce their own power losses and have definite speed limitations. It's just easier to design the motor to turn those sorts of speeds directly and add cells until the voltage is high enough to achieve those RPMS.
In the end you can't get something for nothing. Check out some figures in Motocalc like the guys are suggesting and you'll see how a lot of this dovetails together.
BMatthews is offline Find More Posts by BMatthews
Old Feb 26, 2004, 09:37 PM
quailbird's Avatar
Joined Nov 2003
A big thanks!
Thanks to everyone. I figured it was like small truck with overdrive to get good gas mileage but can't pull heavy loads vs a granny low transmission able to pull heavy loads but poor on gas mileage.
Old Feb 27, 2004, 03:50 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Its moe like dropping a gear to get the thing to climb uphill, versis being in top gear to get the top speed. There is a 'right' gear ratio for every plane and prop.
To an extent, if you drop teh RPM by say two, you will get the same pitch speed if you double the prop pitch, and get the same or more thrust by increasing the diameter. What we should be doing, is looking at the airfarme, and its drag, and working out the most efficient prop and RPM to get that amount of thrust, and then sorting from there backwards.
Old Feb 27, 2004, 10:37 AM
quailbird's Avatar
Joined Nov 2003
OK! I built a 48" delta wing and it came out heavier than I wanted. It's over 2 pounds. Someone sent me a chart on motors and a 400 will lift 1.5 pounds. Tell me, do I need a bigger motor or a gear drive system with a bigger prop and pitch?
Old Feb 27, 2004, 09:08 PM
Marion is offline
Find More Posts by Marion
Marion
USA, NC, Hillsborough
Joined Oct 2003
Take the recommendations to run MotoCal and see what happens for yourself....
Marion is offline Find More Posts by Marion
Old Feb 27, 2004, 09:46 PM
quailbird's Avatar
Joined Nov 2003
What is Motocal and where can I locate it to use it? I looked on the internet and all it said was for robotic arms.
Old Feb 27, 2004, 10:14 PM
rcjetpilot is offline
Find More Posts by rcjetpilot
Bot's like to know where you live
Joined Sep 2003
http://www.motocalc.com/
rcjetpilot is offline Find More Posts by rcjetpilot
Reply With Quote  (Disabled)
Old Feb 28, 2004, 06:20 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
IME,both. Cheapest system that will lift that lot would be something like long can 480, mildly geared - say 2.3:1 - and a prop in the 8-9" bracket, and ten cells/3s LIPO. Yup. 8x6 prop looks good according to motocalc. 18oz of thrust and a 56 mph pitch speed. 9x5 also possible, but straing a little. More thrust, less speed.
Expect to draw between 15and 18A.
If thats not hairy enough for you, next step up is speed 600, or a buggy motor. Geared mag mayhem on ten cells 3s LIPO is allegedly good, but not ever tried it.
Old Feb 29, 2004, 10:34 AM
Bill Mixon is offline
Find More Posts by Bill Mixon
Bill Mixon's Avatar
Georgia
Joined Mar 2002
I've had the best overall results using direct drive motors in delta wing planes.
What does your 2 lb. weight include?
What is the planform like? Airfoil?
Any pictures?
Bill
Bill Mixon is offline Find More Posts by Bill Mixon
Old Feb 29, 2004, 08:55 PM
quailbird's Avatar
Joined Nov 2003
It is a Pibros, only 48". http://gjkool.filternet.nl/s400pibros.html.
I need some help with landing gear moter Foamies (Kits) 4 Feb 19, 2005 06:11 PM
need some help getting the right gear =) jayboy Beginner Training Area (Aircraft-Electric) 1 Jan 01, 2002 11:06 AM
Need some help with my latest plane wim5150 Electric Plane Talk 2 Aug 08, 2001 04:29 AM
A-10 glitching issue...need some help!!! David Hogue Electric Ducted Fan Jet Talk 5 Aug 07, 2001 09:51 PM
need some help finishing my mini ifo. Jeremy_D Parkflyers 4 May 28, 2001 05:49 PM
