Old Feb 24, 2013, 07:55 PM
azflyingguy is offline
Find More Posts by azflyingguy
Gilbert AZ
United States, AZ, Gilbert
Joined May 2012
Hot foam funes
I hot wire and hot knife foam. What should I do not to inhale the fumes? Do you all wear a mask. My wife says I'm killing what little brains cells I have.
azflyingguy is offline Find More Posts by azflyingguy
Old Feb 24, 2013, 08:00 PM
Gilbert AZ
Joined May 2012
Dang I spelled fumes wrong in the title
Old Feb 24, 2013, 10:30 PM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Yup! Looks like the fumes have already done their evil work.
Whiskers is online now Find More Posts by Whiskers
Old Feb 25, 2013, 12:41 AM
TheAeronut is offline
Find More Posts by TheAeronut
12th Pursuit Squadron
TheAeronut's Avatar
Garland, Tx.
Joined Mar 2002
Ideally, a carbon filter mask, but almost nobody wears those. Even a simple dust mask will help a little. You should at least have a fan drawing the fumes away and venting them outside. This would be true regardless of whatever mask you might be wearing.
Heck!!! we should all be wearing a dust mask while sanding, but very few people do. Even I only rarely use a mask.
J.P.
TheAeronut is offline Find More Posts by TheAeronut
Old Feb 25, 2013, 02:09 AM
OutcastZeroOne is offline
Find More Posts by OutcastZeroOne
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
I have a fume evac system I built into my hotwire table. Its just some tubing drawing the fumes through a carbon filter using a heater core fan I pulled out of a wreaked 92 Dodge Colt at my local wreaking yard.
Im going to be remaking this set up into a much smaller system with the table and power supply as one unit.
There is this guy and they also have a fixed version too.
http://www.mpja.com/Solder-Fume-and-...fo/17529%20TL/
Some guys have looked into what is in the fumes and will say its just Co2 and water vapor, but I've run a hot wire for hours and after a while my eyes started to burn. Seems like more then Co2 and water vapor to me.
And I also agree with the mask thing.
OutcastZeroOne is offline Find More Posts by OutcastZeroOne
Old Feb 25, 2013, 08:25 AM
Gilbert AZ
Joined May 2012
Its got to be more then CO2 and water vapor. I feel it in my eyes and in my throat after 30 minutes of cutting foam. This is the foam I'm cutting with a hot knife or wire.
http://www.homedepot.com/h_d1/N-5yc1...kuId=202939038
Old Feb 25, 2013, 05:57 PM
Joined May 2005
yup, ive used that stuff too. The burning is why I have the evac system on my table.
Sold Hot wire foam cutter sixstringlz Aircraft - General - Miscellaneous (FS/W) 7 Jan 15, 2013 05:44 PM
Alert Rip Off By Fune tiny_feet Trader Talk 10 Apr 21, 2009 09:56 AM
For Sale White Spyder Foam - the best hot wire cutting foam there is for DLG wings Sled Driver Aircraft - Sailplanes (FS/W) 2 Mar 15, 2009 07:09 PM
