This thread is privately moderated by Gregor99, who may elect to delete unwanted replies.
Old Mar 14, 2014, 11:22 AM
muscleflex is offline
Find More Posts by muscleflex
muscleflex's Avatar
Leeds, UK
Joined Nov 2004
Oh I see. Thanks.
I have borrowed my friend's PL8 in the past but I never really understood how to use it properly. I even downloaded and printed the manual - all 80 pages if I remember... but I could never get the Accurate charge to work, it used to always stop at 3.80 or something like that.. don't know why, so I used to just charge my batteries as normal. I can't remember which option it was that I used to use..
muscleflex is offline Find More Posts by muscleflex
Old Mar 20, 2014, 06:41 AM
muscleflex's Avatar
Leeds, UK
Joined Nov 2004
Received mine end of last week. Not parallel charged yet but I've been charging my 3s and 1 6s lipo.
I've just finished soldering deans to ec5 adapters last night. Will make some for XT60 as well.. for the MPA board.
Old May 04, 2014, 12:08 PM
595 is offline
595
Find More Posts by 595
595
Australia, TAS, Lenah Valley
Joined Oct 2011
How do I get the text file for PL6 unbalanced storage to read/load. Seems its a txt file and the software is asking for a Single Preset (*.PS6)
595 is offline Find More Posts by 595
Old May 04, 2014, 12:25 PM
Gregor99 is offline
Find More Posts by Gregor99
Seattle
Joined Sep 2007
Remove the .TXT from the filename before importing. The instructions were added to the attachment during upload. But I see they are not visible in the post. I added the text to the first post.
Gregor99 is offline Find More Posts by Gregor99
Old May 04, 2014, 06:18 PM
595 is offline
595
595
Joined Oct 2011
Cheers for that, I've got a bit to learn to use this PL6 to its potential , your posts are very good and thanks for sharing your knowledge. You may also be able to advise why the help tabs in the PL6 CCS don't do anything, well at least for me. I have tried re-installing but still the same. After closing a couple of error windows the file doesn't exist it then opens the complete users guide manual. Is this normal?
Old May 04, 2014, 06:50 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Just to be clear, when you open the CCS, you see the tabs on the top row like in the tour http://www.revolectrix.com/CCS_Tour.htm
But when you click on them, there is no response?
Now you cannot even start the CCS as it gives an file doesn't exist error?
Old May 05, 2014, 12:22 AM
595 is offline
595
595
Joined Oct 2011
No I can use the CCS fine. Only if I click on a help for this tab button or on the help tab in the main menu I get that error. Close the error window ( twice) then the users manual launches complete. I was just using the help tab to see if I could get the info I needed when struggling to load that pre-set. Apart from that the charger control graphs etc. seem to function perfectly.
Old May 05, 2014, 01:33 AM
Gregor99 is offline
Seattle
Joined Sep 2007
The "Help for this tab" quick link attempts to open the manual which is stored in PDF and uses Adobe Acrobat. It should take you to the section of the manual that discusses the tab you are on.
If the clicking the link gives an error, the issue may be with Acrobat. It might be work checking to see you are on the latest version of Acrobat and that its working correctly.
Old May 05, 2014, 04:30 AM
595 is offline
595
595
Joined Oct 2011
Yep that indeed was the issue Acrobat X Pro was up to date but the reader was Adobe Acrobat X 10.1.1 an update to 10.1.9 has fixed it thanks again.
Old Oct 08, 2014, 08:13 AM
davovinch is offline
Find More Posts by davovinch
United States, PA, Meadville
Joined Feb 2011
for those who are using non safe paraboards
wouldn't the use of this adapter from revolectrix upstream of all non safe paraboards combined with inline automotive fuses on the power leads protect the charger from any unfortunate occurances downstream.
davovinch is offline Find More Posts by davovinch
Old Oct 09, 2014, 02:49 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Its not just about protecting the charger. Its also about protecting the packs from each other. Its very easy to reverse a JST-XH balance plug. While you may not be able to plug it in, you can most certainly make contact between the pins. The result is that several of the balance wires become the "fuse" and blow. Its a mess.
The other condition is if the cell is going bad and does not accept a charge. The cell voltage does not rise during the charge cycle. The higher voltage of the other cells in parallel will cause the current to concentrate into the one bad cell. A fuse helps limit the current to the low cell.
Old Oct 26, 2014, 10:46 AM
Joined Feb 2011
unsure of this as it applies to my supply
Power conversion: Synchronous DC/DC converter, supports multiple switcher frequencies of 31.25 kHz, 62.5 kHz, 125 kHz; user selectable by preset
From the user manual. I see it came preset at the middle setting but was wondering what it means.
Is 62.5 the north american standard?
Thanks in advance
Dave
Old Oct 26, 2014, 01:14 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Thanks in advance
Dave
Its the DC-DC tuned to the current range of each preset. All three frequencies are used. Unfortunately, the CCS will not allow you to change these. You can change the setting, but it will not allow you to save a preset with a DC-DC frequency other than the current value.
Old Feb 02, 2015, 09:29 PM
Mr.Aaron is online now
Find More Posts by Mr.Aaron
Team Warpsquad
Mr.Aaron's Avatar
United States, NV, Las Vegas
Joined May 2009
If I want to set a 1s unbalanced storage charge it will discharge it from the PL6 balance port if I read the first page correctly? So would need to make a balance port to jst adaptor with just positive and negative. I did download the preset and tried to load it but kept getting an error mentioning it was a duplicate.
Just wanted to make sure I understand the first post correctly
Mr.Aaron is online now Find More Posts by Mr.Aaron
Old Feb 02, 2015, 11:52 PM
Gregor99 is offline
Seattle
Joined Sep 2007
With the latest firmware there is now a better way to charge 1s cells. There were two new 1s presets added for the PL6 and PL8. These do not require balance leads. Once the new firmware is loaded, select open file to preset on an open slot and select the new 1s presets from the LiPo folder. Post 1 has been updated.
Discussion PowerLab Charge Control Software Quick Tour Tim Marks FMA Direct 15 Mar 31, 2014 06:09 AM
Help! 1S charging lead Assassin-8 Batteries and Chargers 7 Jan 11, 2013 02:41 PM
Question PowerLab 8 parallel 1S "balanced" charging ibrandt FMA Direct 1 Apr 11, 2012 04:53 AM
Mini-HowTo TP-610C Quick Start Guide marc1 Batteries and Chargers 15 Dec 10, 2011 11:12 PM
Discussion FlyCamOne2 Quick Start Guide. Easy to follow. gdavis9999 Aerial Photography 2 Jan 06, 2009 01:04 AM
