Old Feb 02, 2013, 12:54 PM
iamtheav8r is offline
Find More Posts by iamtheav8r
United States, NY, Binghamton
Joined Jan 2013
Looking for a small, lightweight 3D plane
I probably won't do much indoor flying with it, but calm evenings in the back yard would be more fun with a small (24"-31"?) foamie. I've been looking at the Mini Breeze (24") and the Yak54 (31") and wondered if there are other options that you might recommend to me? Or maybe these are good, but there are some options on components to use?
iamtheav8r is offline Find More Posts by iamtheav8r
Old Feb 02, 2013, 09:33 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
Check out the "Crack Yak Mini"(http://www.rcgroups.com/forums/showthread.php?t=1786763) also look into Fancy Foam,(http://www.fancyfoam.com/index.php?m...index&cPath=21) TAS Foamies,(http://tasfoamies.webs.com/3034indoorfoamies.htm) and Bowker Aero Models.(http://www.bowker-aircraft.com)
Hope this helps,
Free
Free is offline Find More Posts by Free
Old Feb 03, 2013, 06:14 AM
Stark is offline
Find More Posts by Stark
Don't worry be happy :)
Stark's Avatar
Joined Sep 2001
I have the Crack Yak Mini and can really recommend it! Great little plane!
For flying really close and slow I use the 6x3 prop.
This is with 7x3.5. A lot of power!
Crack Yak Mini in the snow (3 min 5 sec)
Richard Starkenberg 2012-12-29 (1 min 58 sec)
Stark is offline Find More Posts by Stark
Old Feb 03, 2013, 10:44 AM
Joined Jan 2013
https://vimeo.com/56388069
http://www.youtube.com/watch?v=_G7-BOLoCCI
May I ask what systems you're using? Motor, battery, esc, servos?
Looks like it flies great!
Old Feb 03, 2013, 11:07 AM
Stark is offline
Stark's Avatar
Joined Sep 2001
I'm using the recommended DualSky XM2212RTR-25 Motor/ESC combo but the servos are not available in Sweden so I'm using the Dualsky DS3101. The batteries are 300 mAH Desire Power.
Flying weight is 88 grams.
Old Feb 03, 2013, 01:06 PM
Joined Jan 2013
Thanks...just ordered the Crack Yak and everything else I'll need for it. Looking forward to flying this little one!
Old Feb 03, 2013, 01:31 PM
Stark is offline
Stark's Avatar
Joined Sep 2001
Great to hear! For building instructions and tips check in this thread: Twisted Hobbys - Crack Yak Mini - Build Thread.
Discussion Looking for a small camera system for remote viewing deathrow Radios 5 Jan 31, 2013 05:56 AM
Discussion Looking for a composite lightweight 90mm jet? firehawkzach Electric Ducted Fan Jet Talk 21 Jan 25, 2013 06:26 PM
Found looking for a small 3d plane in DFW only (dallas/fort worth) FASTBEN Aircraft - Electric - Airplanes (FS/W) 4 Sep 11, 2009 01:41 PM
Looking for a small, balsa, 3D plane like the lil banchee... papasmurf 3D Flying 8 Jun 12, 2005 08:12 PM
Looking for plans for a small 3D plane Erik Johansson Parkflyers 2 Dec 08, 2002 07:03 PM
