Old Jul 18, 2013, 08:24 PM
Test Pilot Mafia is offline
Find More Posts by Test Pilot Mafia
CSU Chico, Flight Club
Test Pilot Mafia's Avatar
United States, CA, Chico
Joined Sep 2012
Originally Posted by RCvertt View Post
TPM- Do you have (#defined MotorStop) uncommented in (config.h)?
Rimshotcopter- Looking good there.
my "find text box wont work" I cant find any #define motor stop anywhere manually in config.h.
It happened again, I stepped on it, but kept the battery plugged in. while doing so:
-the arm switch and throttle failed to function entirely.
-disconnecting the throttle wire from the RX changed nothing. rotors continued to spin.
-disconnecting the ESC signal wire stopped the rotor in about 2 seconds. upon reconnection the system refused to spin up.
I think this is unique to my system setup in either the ESCs or the MWC/arduino settings.
I wonder if I enabled the lines of failsafe code? the top most one is commented out.
Test Pilot Mafia is offline Find More Posts by Test Pilot Mafia
Old Jul 19, 2013, 07:13 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
I wouldn't use the arm/disarm switch until you get it flying good. Use the TX yaw arm/disarm movement instead.
Motor_Stop is near the bottom of the file. It shouldn't be activated until everything works good.
Sounds like time to clear the eeprom and start with a fresh (2.2) file.
RCvertt is offline Find More Posts by RCvertt
Old Jul 21, 2013, 10:43 AM
Joined Sep 2012
found it!
it was a deceptive intermittent BEC, cuasing a short duration off, then immeadiatly back on, but the MWC needs a boot time, in that time my ESC fell back to a minimum throttle waiting for a response that would never come.
well lesson learned on that one... all of those 3-pin servo connectors are delicate and to be checked often...
so ill change some connectors and figure out a more formal test for those... I cant lose a whole machine because of this type of error...
EDIT: Ive replaced the connector but now cant get the MW crius to arm, when I use a servo tester I can get both props to turn though.
Old Jul 23, 2013, 01:41 PM
Joined Sep 2012
ok ive reflashed some FW, and will be making some test filghts today, but im still having problems with the RCtimer collets wobbling all over, ive seen others have this problem too, I may need to buy the Eflight type.
Old Jul 23, 2013, 11:57 PM
Joined Sep 2012
ive reflashed and reprogrammed some important parts of the machine, and built a jig to un-bend the worthless collets, which now work much better.
ive added more ballast to the tail, and I see that the closer the CoL and CoG are the better behaved the machine is, even with non optimal PID tuning. the tail fin is to be added shortly, and will be flexible CF and removable. and for the first time, I think im seeing hints of the machine hovering level instead of slightly nose down, as with the previous generation I operated.
Second, a force diagram/free body diagram and general guidelines would help with the build and tuning process, but im not sure where to begin with that. in any case, the best advice I can give from lessons learned first hand, is that the control horn should be long, the servo horn considerably shorter, and the prop disc should tilt very little even with the full rotation of the servo from limit to limit. (remember youll want full resolution from the servo and PID math, these general points help you get there.)
Old Jul 25, 2013, 12:24 PM
Joined Sep 2012
the changes ive made, so far are profound and allow much better control then ever seen before. Just a simple 1 inch elevation change prevents the wicked oscillation seen on all my machines before.
Old Jul 29, 2013, 11:15 PM
Joined Sep 2012
im going to try and get a real physical example modeled, and Gress' work here in this pic may help.
Old Jul 30, 2013, 05:29 PM
Joined Sep 2012
Found this PDF, trying to figure on the meaning of all the funny math... Gress isnt credited though he clearly contributed.
Old Dec 31, 2014, 01:09 PM
kicekilla is offline
Find More Posts by kicekilla
No you cant fly it.
kicekilla's Avatar
United States, CA
Joined Mar 2011
what ever happened here? get her flying? I am picking back up where I left off.
kicekilla is offline Find More Posts by kicekilla
Old Dec 31, 2014, 02:20 PM
Joined Sep 2012
yes got it working, but it absolutely needs a tail as rimshot always advised.
The tail features (i think) seemed to be:
-- aerodynamic, tail fins could be used, there surface area resists via drag.
-- mass, a tiny mass far away from the CG/CT, as I=mr^2 indicates.
-- the length of the lever arm longer means increased effectiveness of the above.
adjust these tail factors as needed. (obviously dont go adding a brick the the tail) were trying to fly here.
The purpose of the tail is the reduce the speed of oscillation, such that the flight controller can act faster than what its trying to control - without overshoot. Servos take time to move, even with the fastest micro-controller or supercomputer.
the problem, and why i moved to tricopters, was that with the tail, i exceeded the dimensions allowed in the competition.
the OAT idea is my favorite though im currenty building and operating a tricopter. ill be moving on to a quad and bi tilt-rotor soon.
For Sale Fourteen Motors, EDF's, & ESC's: Castle HV160; TamJets TJ90; Himax; Hacker; Turnigy jgalexander Aircraft - Electric - Power Systems (FS/W) 4 Jan 28, 2013 07:55 PM
Sold Two NIB Castle Creations ICE2 HV160 Lite ESC's jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Jan 18, 2013 11:28 PM
Sold Two Castle BEC'S, One New and One lightly used mechengineer03 Aircraft - Electric - Power Systems (FS/W) 2 Jan 09, 2013 10:21 PM
Sold Two NIP + One Used Castle Creations ICE2 HV80 ESC jgalexander Aircraft - Electric - Power Systems (FS/W) 5 Jan 08, 2013 02:13 AM
Sold Two USED Castle Creations Phoenix 25A ESC's (((SOLD))) bah7566 Aircraft - Electric - Power Systems (FS/W) 4 Jan 07, 2013 10:56 AM
