Old Dec 22, 2012, 03:15 PM
Alan Sherwood is offline
Find More Posts by Alan Sherwood
Melbourne, Australia
Joined May 2005
Ballast System for Small Indoor Airships
I present here a ballast system for very small indoor airships.
For no reason other than as an operational scale detail, I made a ballast system for a model zeppelin LZ5 (details of this were in airshipmodeler.com, now apparently defunct site). 1st pic shows the system. Empty weight 1/3 gram. 2nd pic is close up of the transparent tub, which can hold 1 gram of liquid ballast
Next 2 pics show the operation. A memory wire pulls on a thread wrapped around the tub to rotate it, while elastic (black cord) rotates it back when the memory wire is de-energised. 5th pic shows it unballasting; when operating it drains a full tub in about 20 seconds.
The tub (shown removed in next pic) has a Teflon tube which is a close fit in the aluminium tube on the holder. Holes in each tube (one can be seen in the teflon tube) line up when the wire is energized and allow flow. I works well with methylated spirits, but not water (due to high surface tension). The transparent shroud around the bottom of the aluminium tube is necessary to stop the fluid wetting the outside of the tube and flowing all over the rig, rather than dripping off.
I have not yet flown the model with this system installed, so canít yet say whether it actually does anything useful. Will report when flown.
Alan Sherwood is offline Find More Posts by Alan Sherwood
Discussion 15' indoor brushless airship for sale Greg McNair Blimps 3 May 13, 2013 09:07 AM
Sold small power system for a small plane chyorn Aircraft - Electric - Power Systems (FS/W) 2 Nov 20, 2012 08:50 PM
Discussion I Need Help on GPS/Autopilot for Indoor Arena Airship Ed Couch UAV - Unmanned Aerial Vehicles 10 Dec 07, 2009 09:39 AM
Wanted Complete power system for small indoor depron plane sidecar53 Aircraft - Electric - Power Systems (FS/W) 1 Sep 26, 2009 12:55 AM
indoor airship for kid Cabane Blimps 9 Aug 21, 2004 10:58 PM
