Old Jul 20, 2013, 08:24 AM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
Hi guys!
Today I finally took some time to test HK Alti logger (actually it is Altitude permit logger) in role of ordinary alti logger.
And what a day! I manage to use thermals and soar my Marabu so high, that I starts to feel uncomfortable (bad visibility..moisted air) so I drop flaps and sprial nose down to "safer" height. Of course I was trying to thermal on that low height and was going up. As dinner was served on the table, and I was also impatient to see what will show the Alti logger on the computer, I landed.
This is the log:
Legend: red line=power on, yellow line=motor off, green line=temperature
Before a peak height, I have 2 thermals with average 1,6 m/s climbing.
Not bad for a "box" as Marabu is!
ultralajt is offline Find More Posts by ultralajt
Old Jul 20, 2013, 08:44 AM
ultralajt's Avatar
Joined Sep 2004
IMPORTANT NEWS!
Now, DXF files for CNC cutting of the parts, included with plans! No extra cost!
Marabu Plans!
Old Oct 12, 2013, 04:14 AM
ultralajt's Avatar
Joined Sep 2004
I build 2 axis brushless gimbal (HobbyKing Martinez clone electronic) and install it on the Marabu wing at wing strut joint. It needs some tinkering, but even now I am pleased with a result.
Just casual flying above my village... (6 min 12 sec)
Old Oct 14, 2013, 06:41 AM
Scott C is offline
Find More Posts by Scott C
no B'arf zone
Scott C's Avatar
United States, GA, Peachtree City
Joined Aug 2000
Beautiful, I am not a quad pilot, but I assume that you had to use a flight controller with pitch and roll outputs.
Scott C is offline Find More Posts by Scott C
Old Oct 17, 2013, 01:45 AM
ultralajt's Avatar
Joined Sep 2004
I use gimbal that is attached at strut joint with wing.
Gimbal is stabilized by Martinez controll board, that drive two brushless motors acutating camera pod.
The sensor board has option for attaching it into 3 slots, that allows camera to aim horizontal, 25° and 50°below horizont, without need of extra free channel on TX.
Here is a video, that show all three camera views and another, aiming away from the fuselage side along the semispan:
Marabu couple of starts and landings (0 min 0 sec)
And this is a camera view towards the model:
Marabu flight 2axis brushless gimbal (2 min 47 sec)
Mitja
Old Jul 07, 2014, 06:22 AM
ultralajt's Avatar
Joined Sep 2004
Another flight avanture with Marabu!
Flying trough a hole in the fog, to see what is above:
PLAYING IN THE FOG (2 min 39 sec)
Old Jul 07, 2014, 06:23 AM
ultralajt's Avatar
Joined Sep 2004
Just a short video, kind of Marabu walkaround:
Marabu walk(by)around (1 min 35 sec)
Old Jul 07, 2014, 06:29 AM
ultralajt's Avatar
Joined Sep 2004
PLANS here!
Free download plan sample here!
Old Apr 18, 2015, 06:58 PM
walksonsun is offline
Find More Posts by walksonsun
Joined Apr 2015
new here need help with dxf files of marabu
i bought the marabu plans today and the pdf files open fine but i cant get the dxf files to open with lazycam or turbocad or any other cad or cam program please help jerry
walksonsun is offline Find More Posts by walksonsun
Old Apr 19, 2015, 08:04 AM
ultralajt's Avatar
Joined Sep 2004
Check your email. I send you another DXF file that is compatibile with year 2000.
Old Apr 19, 2015, 08:12 AM
ultralajt's Avatar
Joined Sep 2004
When talking about Marabu, I am playing with idea to build it completely out of 3mm thick white poplar plywood, except airfoil nose and narrow leading edge planking will be made from balsa.
I already made test wing rib bay to check the assembly, weight, strength and rigidity. After having part in my hands, I made some corrections in the new plan. This version of Marabu will probably weight a bit more than "original", but will be piece of cake to assemble comparing with original one of this thread. It will be perfect as KIT complete.
Build Log Build log PIK-7 Harakka II, 1:4 (2,65m) with free plan tuootal Scale Sailplanes 156 Mar 17, 2015 11:07 AM
Discussion Giezendanner Marabu 1972 (most likely year) kit. bossee Classic Pattern Flying 18 Oct 12, 2013 02:27 AM
Build Log My Giant Parkflyer MARABU ultralajt Parkflyers 39 Dec 16, 2012 09:16 AM
Discussion Would 800W motor with 1150 do for a 2-3kg-ish RCM trainer? minivation Power Systems 5 Aug 27, 2011 12:22 PM
Discussion Marabu 6 Lone Ranger Electric Sailplanes 0 Dec 21, 2008 03:09 PM
