Old Nov 24, 2012, 03:25 PM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
Raiden needs more speed
Hi all,
I have a Kyosho Raiden. It has a fat (scale) fiberglass fuse and builtup 35" wing. Right now I have a Himax HC3516-0840 (840KV) motor on 4S 3300 30c battery spinning a 10x7 prop. This produces 422 watts and 29 amps. After flights the battery is barely warm but the motor is very warm (can just keep your hand on it). It seems to fly between 50-60 mph max.
So my question is, what is the best way to get more speed?
Going with a 10x10 prop will do it but I fear the motor may over heat.
Any recommendations on motor and prop combos to use with 4S to get around 65-75 mph?
Granted the cooling is very limited. I will drill out more cooling holes in front of the motor. More importantly I will open up some exhaust air holes at the rear of the fuse (I have none now). I will do this and fly tomorrow and give results on how hot the motor is (by touch). If it cools down the motor I'm going to throw a 10x10 prop on.
Kevin
RCDad is offline Find More Posts by RCDad
Old Nov 24, 2012, 04:54 PM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
San Pedro,Ca
Joined Sep 2004
Originally Posted by RCDad View Post
Hi all,
Kevin
I never liked the Himax motor cause they do run hot . You might what to try a higher kv motor
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Question Need more Speed!.. but dont wanna blow up!! DeadServo Motorcycles 6 Oct 09, 2012 10:20 AM
Discussion Need updated motor to gain more speed.. aclinml Power Systems 3 Aug 15, 2012 09:37 AM
Question Need More Speed on F.Jet Ultra: Bigger Prop or Smaller one? rcwarrior Power Systems 4 May 25, 2012 12:42 AM
Help! I NEED MORE SPEED!!! need some help!!!! cjmartinez103 Power Systems 18 Apr 29, 2012 12:20 AM
Help! I need speed and more speed GreenTraxxas Car Talk 16 Feb 24, 2009 12:51 AM
