Old Mar 03, 2015, 12:44 AM
changosurf is offline
Find More Posts by changosurf
Joined Aug 2011
question for D.Frie,
is there much practical difference in calculating 'mah/km' and 'distance remaining' using averaged data (total mah used/total distance traveled) vs instantaneous data (using speed & amperage)???
I'm working on my own OSD project and would like to integrate these features into my OSD. However, I haven't actually used these metrics much in the past, so I'm not sure if there's a noticeable difference in usefulness of one vs. the other.
So far, I've set up the averaged values (using total mah used vs distance traveled), and would just like some insight on if this should be ok, or if really does help to include the instantaneous measurement
changosurf is offline Find More Posts by changosurf
Old Mar 08, 2015, 10:10 AM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
I use D.Frie code on RTFQuads minim OSD on many rigs without issue. It works awesome!
RTFQuads recently released a Micro MinimOSD which runs D.Frie code no problem apart from no voltage reading?
Mine is stuck @ 6.5 volts. I can confirm the BAT2 input goes via resistor divider to pin 23 of the Atmega 328 (ADC0) - just like its bigger brother OSD.
Im guessing its a code issue then?
badlands is offline Find More Posts by badlands
Old Mar 08, 2015, 03:03 PM
badlands is offline
badlands's Avatar
Joined Mar 2010
**UPDATE** I have to use the FTDI to flash this OSD, I have to use the 'Clear Eprom' sketch before I flash with D.Frie code - that seems to work!
Old Mar 20, 2015, 11:56 AM
bparini is offline
Find More Posts by bparini
bparini's Avatar
Paraguay, Central, Lambare
Joined Mar 2013
Hi badlands!,
I buy the same MicroOSD board, i am plan to use with:
Flytron MTK GPS Module
Flytron 50A Current Sensor
Denis Firmware.
And put in my "Spywalker" (Spyhawk electronics + mini Skywalker frame).
You have video of the OSD working?
Regards,
Bruno.
bparini is offline Find More Posts by bparini
Old Mar 23, 2015, 01:53 PM
gie666 is offline
Find More Posts by gie666
Indonesia, West Java, Bandung
Joined Nov 2014
hi dennis, i have succed make ones, but i have problem. I have 2 cameras camera one is ok but other camera its panasonic i think. when attach the camera the osd wont show up, but when I disconnect the camera its showing. whats the problems?
gie666 is offline Find More Posts by gie666
Old Mar 23, 2015, 01:56 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Most likely a mismatch between PAL/NTSC.
Check it out and let us know if that solves the problem.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Mar 23, 2015, 02:30 PM
gie666 is offline
Joined Nov 2014
I have try is using PAL/NTSC its still same, but when I upload your firmware to minim osd and using same camera its works. but using your hardware its not works
Old Mar 24, 2015, 07:26 AM
lucafedechen is offline
Find More Posts by lucafedechen
lucafedechen's Avatar
Paraguay, Asunción, Asuncion
Joined Jun 2009
Hi..my rx pins in atmega not works, I think I burned..ftdi not communicate, I re upload bootloader in atmega, I only able to flash trougt isp programemer now, it's possibel to mod the code and use another free pin to receive gps data??
lucafedechen is offline Find More Posts by lucafedechen
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
