Old Nov 05, 2012, 10:03 AM
greg harrison is offline
Find More Posts by greg harrison
United States, MS, Columbus
Joined Aug 2008
Busa 1/4 d-7 rim fire 50 cc?
I'm building a busa 1/4 scale d-7. It should be about 20 to 25 lbs. I'm trying to decide gas or electric. If I go gas I want it to be a four stroke. I don't know if the saito fg-36 has the power to pull this plane. For electric I have everything but the motor. I have never used a rim fire motor and was wanting to know if this is a good choice or is there a better choice for this plane? This will be the heaviest plane I have by 10 lbs or so. A power 110 is the largest motor I have used so this is new to me. Any help will be greatly apperciated
greg harrison is offline Find More Posts by greg harrison
Old Nov 12, 2012, 09:46 PM
aeronately is offline
Find More Posts by aeronately
aeronately's Avatar
Camarillo, CA.
Joined Aug 2002
BSUSA 1/4 Fokker DVII
Greg:
I built the Arizona DVII about 5-6 years ago.Did it in Lothar von Richthofen's
colors. Nice.
I over-built my machine and it weighs 29.3 pound gross t.o.weight. Yes, your busa will be about what you estimate weight-wise and should require far less power than mine does. I use a Quadra 40 XL gasser. The airplane is very under powered with the 40 and obviously needs a 50. Your DVII could do well with a 40.
Incidentally, my Quadra leaves plenty of space for a dummy Mercedes which on-lookers love. And the engine is very docile to start and handle.
Regrettably my ship tends to bend my 5/32 axles which may be due in part to the
soft music wire. I don't think you will not have that problem.
Nathan Rambo
Camarillo, CA.
aeronately is offline Find More Posts by aeronately
Old Nov 15, 2012, 08:40 PM
Joined Aug 2008
Thanks for the info. I was reading a thread on rcscalebuilder and a guy had one at 18 lbs. everything was in front of c g. And no scale cosmetics. Built just for flying. I may try to get mine below 20 lbs also and then get another for scale. I am doing the Carl Degelow scheme. There is a thread where a guy made an operative landing gear and he sales them.
For Sale Homebuilt quad frame, Aeroquad 1.7 imu shield, arduino mega, and 4 props $50 OBO firehopper Aircraft - Electric - Multirotor (FS/W) 2 Aug 07, 2012 05:23 AM
For Sale 1/4 BUSA Sopwit Pup Electric RTF mmclaug858 Aircraft - Electric - Airplanes (FS/W) 0 Jul 30, 2012 12:45 PM
Sold BUSA 1/4 scale cub davezagwyn Aircraft - Fuel - Airplanes (FS/W) 4 Jul 13, 2012 11:22 AM
For Sale Rim Fire 1.60 63-62-250kv $120.00 Wildblue Aircraft - Electric - Power Systems (FS/W) 0 Jun 02, 2012 08:48 PM
Found Rim Fire 42-50-800 mmclaug858 Aircraft - Electric - Power Systems (FS/W) 1 Mar 02, 2010 08:41 PM
