Old Nov 02, 2012, 11:45 AM
skypup is offline
Find More Posts by skypup
san antonio, texas
Joined Mar 2002
Stuck valve saito 60 t
I tried running a saito 60 twin and discovered it has a stuck valve. Any ideas on how to free it up? Not sure about dissassembly. The rockers are held on with e clips. Can I just unbolt the affected cylinder without screwing things up? Thanks.
skypup is offline Find More Posts by skypup
Old Nov 02, 2012, 03:01 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
Yes you can. You will have to dissconnect the intake manifold. Also remove the valve covers. Once you remove the cylinder you will be able to look into it and see the valves. You could try pressing on the valve stems to open the valves and use a brush and some fuel to wash out anything that may be stuck between the valve and the seat.
If this is a old engine, that hasn't run in awhile, it may just need a good cleaning. Old built up castor can be removed with heat.
tacx is offline Find More Posts by tacx
Old Nov 02, 2012, 03:16 PM
skypup is offline
san antonio, texas
Joined Mar 2002
Thanks. It is an old but looks like new engine with apparently little run time.
Old Nov 02, 2012, 04:25 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You can remove the rocker covers and heat up the head good with a hair dryer or heat shrink tubing gun. Usually it is some old congealed castor oil. Once it frees up some liberally douse it with some penetrating oil and keep working it so the oil gets in there more.
earlwb is online now Find More Posts by earlwb
Latest blog entry: My new Gaui X5 Rc Helicopter
Old Nov 02, 2012, 04:48 PM
skypup is offline
san antonio, texas
Joined Mar 2002
They're free!
I kept spraying wd 40 into a small container and pouring it onto the rockers and into the rod tubes. Last time I checked everything freed up! I added some air tool oil, buttoned things up and she fired right up. Ran well.
I'n not use to twins. Is it typical for one cylinder to run hotter? Thanks.
Old Nov 02, 2012, 05:11 PM
706jim is offline
Find More Posts by 706jim
My 60T had a broken camshaft. Check that if you have trouble keeping the valves set.
706jim is offline Find More Posts by 706jim
Old Nov 02, 2012, 05:26 PM
skypup is offline
san antonio, texas
Joined Mar 2002
Thanks!
Sold New - Ultra Precision UP-8 Retract Valve, Quick Disconnects, air fill valve, 1/16th T whatasteele Aircraft - General - Miscellaneous (FS/W) 1 May 09, 2012 07:34 AM
Discussion OS 60 needle valve o-ring RC JD Engines 6 Mar 06, 2012 05:20 AM
Wanted Needle Valve early Rossi 60 & S.T. idle needle jjscott Aircraft - Fuel - Engines and Accessories (FS/W) 3 Mar 31, 2010 07:32 AM
Discussion YS 120 stuck valves pacoflyer Engines 8 Dec 31, 2009 11:21 AM
Help! YS120 stuck valve. Short of an overhaul, what can I use? RayMara Engines 12 Jun 03, 2009 04:50 PM
