Old Oct 19, 2012, 04:57 AM
eshchari is offline
Find More Posts by eshchari
Joined Oct 2012
x525 v3 setup
hi all
my name is ilan from israel.
i just finished my x525 v3 ( black board 5.5).
after callibraiting using info from rcgroup
the quad doe'snt react correctlly.
it turns to the left what ever i do and the motors are not
responding corectlly.
any ideas ????
thanks
eshchari is offline Find More Posts by eshchari
Old Oct 19, 2012, 05:03 AM
ElectroDie is offline
Find More Posts by ElectroDie
Joined Oct 2012
Calibrate the ESCs again
Adjust your trims on your radio (probably yaw)
Check solder connections between ESCs and motor
ElectroDie is offline Find More Posts by ElectroDie
Old Oct 19, 2012, 05:38 AM
Woppit is offline
Find More Posts by Woppit
Woppit's Avatar
United Kingdom, Hastings
Joined Jul 2012
Originally Posted by eshchari View Post
hi all
any ideas ????
thanks
Hi, I use the black board 5.5 FC running KK 4.7 X firmware, I have to reverse the yaw gyro on mine.
What firmware are you using, if it's 4.7 you will probably need to do it to.
Woppit is offline Find More Posts by Woppit
Old Oct 19, 2012, 08:20 AM
eshchari is offline
Joined Oct 2012
well at the moment i found 2 of the outrunner free on the shaft so i have to tight it up unfortunatlly i don't have the alen size (it is very small) .
only after fixing it i shall check it all.
it took me 4 hours to understand why the motors are running but not on the correct speed.
ilan
Old Oct 19, 2012, 11:52 PM
p0st4L is online now
Find More Posts by p0st4L
BUILD.FLY.CRASH.REPEAT.
p0st4L's Avatar
United States, CA, Santa Cruz
Joined Mar 2012
When I was running the KK 5.5 board, the 4.7 Firmware didn't work for me. I had to go down to 2.x for it to be able to fly right. but once at the lower version of firmware, it was just fine.
p0st4L is online now Find More Posts by p0st4L
Old Oct 20, 2012, 12:52 AM
hobiej is offline
Find More Posts by hobiej
Canada, AB, Calgary
Joined Sep 2012
ilan
What motors are you using to have this happen? I had 2 motors do the exact same thing, I tested it at home and was flying just fine, went to the field with a friend.... wanted to flip. Took a bit to figure out, but the same thing, the set screw loosened off! I just put the can back in place, and put some locktite in to help hold it, seems to be working..... for now! lol
The motors I were using were Turnigy 2822-1100 Kv. Have 16 of these (in different sizes) and never seen this yet????
hobiej is offline Find More Posts by hobiej
Old Oct 22, 2012, 05:15 AM
flahut59 is offline
Find More Posts by flahut59
flahut59's Avatar
France, Nord-Pas-de-Calais, Oignies
Joined Dec 2008
Hi all,
I bought on HK the x525 v3 frame (http://www.hobbyking.com/hobbyking/s...ame_600mm.html).
I wonder which motor is the best between these 2 brushless, I just want to fly longer.
http://www.bidproduct.com/part/Produ...MOTOR_278.html
http://www.bidproduct.com/part/Produ...MOTOR_277.html
Sorry for my english
Thank you for your precious help.
flahut59 is offline Find More Posts by flahut59
Old Oct 22, 2012, 08:04 AM
dums2000 is offline
Find More Posts by dums2000
France, Auvergne, Clermont-Ferrand
Joined Jul 2012
@flahut59 :
( <french mode> je suis français aussi (clermont-ferrand) , mais je vais répondre en anglais, on est sur rcgroups </french mode>)
To put on your X525 frame, here is my shopping list :
- rctimer 2826-13 1000kv (works great ! )
- Simonk 30A ESCs ( available on rctimer too)
- 2600mAh nanoTech lipos (hobbyking), (flight time : 10 minutes)
Bests,
Christophe.
dums2000 is offline Find More Posts by dums2000
Old Oct 22, 2012, 08:46 AM
flahut59 is offline
flahut59's Avatar
Joined Dec 2008
Thanks a lot Christophe, but this one seems to be the same?
Right or wrong?
Old Oct 23, 2012, 02:02 AM
dums2000 is offline
Joined Jul 2012
Not the same, your link show 2212-13 motors , rctimer are 2826-13. ( 28 is the diameter, 26 is the heigh), but according to specs, kv value and shaft diameter are equals.
I really recommand 1000kv and 28 as diameter to put on X525 frame.
Sold X525 V3 QuadCopter bstussie Aircraft - Electric - Multirotor (FS/W) 4 Feb 24, 2012 11:34 AM
Discussion Introducing X525 V3 From CSL-Hobby CSLHobby Multirotor Talk 9 Feb 15, 2012 11:00 PM
Discussion X525 v3 build help please llVAPOURll Multirotor Talk 2 Jan 17, 2012 06:45 PM
Sold Foldable Quad copter X525 V3 frame bdpowers Aircraft - Electric - Multirotor (FS/W) 7 Sep 19, 2011 12:23 AM
