Old Jul 02, 2012, 09:15 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
If you are refering to the defaults for performance guide settings, I would keep max rate for aileron and elevator stock. Maybe add about -25% expo. And finally zero out cyclic to tail rudder comp.
ridge_racer is offline Find More Posts by ridge_racer
Old Jul 02, 2012, 09:43 PM
Kauaiguy is offline
Find More Posts by Kauaiguy
Kauai
Joined Jan 2011
I will give that try tomorrow , it was to windy to tell how well it was flying but the gyro sure compensated for the wind.I also noticed my servos where much quieter while sitting on the bench during setup or while it was still( with my Cx the servos where noisy ).Looking forward to flight test next!Thanks again
Steve
Kauaiguy is offline Find More Posts by Kauaiguy
Old Jul 03, 2012, 04:29 AM
Joined Nov 2010
Are you using analog or digital servos?
Old Jul 03, 2012, 07:36 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Any news on how this compare to the Beastx / Tarot ZYX yet ?
I need another FBL controller and it is down to these 3 at the moment (or possibly wait for the MSH Brain).
Mike.
MikeHRC is offline Find More Posts by MikeHRC
Old Jul 03, 2012, 10:19 AM
Kauaiguy is offline
Kauai
Joined Jan 2011
I'm using the Kstds115mg mks95 clone , it's the same one they used in there setup videos.With the Cx 3x1000 the same servo are noisy and they didn't work well ( had to turn the cyclic gain down to 22) and I have them set to the right hz.Also I had vibration issues with the Cx but with the Robird it's smooth as silk with the supplied gyro tape and at all default settings.I took my heli Out again in lighter winds just before evening and did a few loops and fast circuits and really like how it feels so far.The software was very easy to use and was quick to setup.So far this one is a winner!The Beastx and Tarot don't have a built in governor and the Robird's next software update is supposed to include it!
Steve
Old Jul 03, 2012, 06:48 PM
Joined Nov 2010
Mike.
It is kinda a tie between this and the Beastx V1 clone(HB800) for me. However the HB800 have slightly better tail tuning. The 3GY has really good PC software and is very tunable via the performance guide tab. I also feel the piro optimization is best in class too. Now both of these gyros to me are better than the old Tarot/CopterX/ALZRC 3gys in a sense that they seem to work better and run higher gains with analog servos. I use digital servos right now on both for rock solid stable hovers and 70-75% gains.Beenflying will be able to give more insight as to how it compares to a real Beastx in a few days.
Old Jul 03, 2012, 11:20 PM
IFHELI is online now
Find More Posts by IFHELI
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
http://youtu.be/Z1OISc9dK3I http://youtu.be/nkl046t1O40
IFHELI is online now Find More Posts by IFHELI
Old Jul 06, 2012, 11:44 AM
Kauaiguy is offline
Kauai
Joined Jan 2011
Himodel has the Robird for sale at $66 dollars+ $9 shipping!Might have to get another.
Steve
Old Jul 06, 2012, 12:00 PM
MikeHRC is offline
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Steve
I ran out of self-control and put in my order with them a couple of days ago
Old Jul 06, 2012, 04:31 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
That price is looking good! With the continued work robird is doing on this gyro (working with a pro and adding governor), we could end up with a gyro the equivalent of the Mikado Vbar.
Just an FYI, I've started another thread that will have a review and a resource of information (also links back to this thread) in the first post here:
http://www.rcgroups.com/forums/showthread.php?t=1685138
beenflying is offline Find More Posts by beenflying
Old Jul 06, 2012, 04:50 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I'm putting that in the first post.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Jul 22, 2012, 10:56 AM
GetToDaChopper is offline
Find More Posts by GetToDaChopper
Aviation Technician
GetToDaChopper's Avatar
Joined Feb 2012
i'm glad i have better self-control than most......
GetToDaChopper is offline Find More Posts by GetToDaChopper
Old Jul 22, 2012, 11:57 AM
Kauaiguy is offline
Kauai
Joined Jan 2011
My second Robird will be here in a few days and I'm thinking of a third.123 trouble free flights so far.I got to flight 6 on my cx3x1000 before it cost me,I add those cost when a calculate value for the money,it's total cost to operate, plus having your heli buss your head on takeoff will change you( near miss)!
Steve
Old Jul 22, 2012, 01:39 PM
IFHELI's Avatar
Joined Apr 2010
I got in two test hovers with the Black Widow and new 3GY. They both performed as well as my original 3GY. I used the same performance guide settings on all three and even the same gain setting on tail. Both pots on gyros are set just on the + side of center on all three. I can not wait to get out and see if they all fly about the same.
Old Jul 22, 2012, 02:02 PM
Kauaiguy is offline
Kauai
Joined Jan 2011
I know it's not a fair test but how do the vib-analysis numbers compare?
Steve
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Build Log ALZRC 450 pro V2, More bling then JLo! Hot_Wheels Mini Helis 19 Mar 13, 2012 12:30 AM
Discussion ALZRC 450 Pro V2 FBL Radio and 3x1000 FBL placement electrojolt Mini Helis 2 Feb 05, 2012 06:28 PM
