Old Apr 12, 2012, 08:55 PM
mamba max1 is offline
Find More Posts by mamba max1
mamba max1's Avatar
United States, NC, Durham
Joined Jun 2010
One esc really hot?!!
First, here is the set up:
HK SS 18-20A esc's flashed with Simon software
20-28m motors (1050kv) http://www.hobbyking.com/hobbyking/s...idProduct=4701
2200 mah lipo (20C)
Crius multiwii with 2.0 update
Problem:
I just got everything hooked up and I am in the "getting it all right" stage before I go out and try to fly. Well, one of my esc's gets pretty hot. At first, it would stutter the motor. So I re-calibrated the throttle endpoint for that esc. That fixed the problem, but it now gets hot! I'm not even flying, just bench testing. The other esc's are perfectly fine, but this one gets hot quickly.
Also, the motor connected to this problem esc sounds different than the other motors. (more of a whine sound...its louder) I did clarify that all esc's worked right after flashing them with Simon software. Should I try re-flashing this esc?
EDIT: I am using the bec from one of the esc's to power everything, but it is not the hot esc. The bec esc stays perfectly cool.
Any ideas?
mamba max1 is offline Find More Posts by mamba max1
Old Apr 12, 2012, 09:12 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
Hawaii
Joined Feb 2003
2200 mah lipo (20C)
Problem:
Any ideas?
Are you flashing with the proper firmware. SimonK has a few different firmware. I out when I flashed the wrong software the ESC will stutter the motor and doesn't start smooth.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Apr 12, 2012, 09:14 PM
mamba max1's Avatar
Joined Jun 2010
I did use the correct firmware (tp.hex per the database). After flashing each esc, I bench tested each individually. All worked perfectly. (then)
Old Apr 12, 2012, 09:32 PM
mamba max1's Avatar
Joined Jun 2010
Ok, I just swapped esc's and motors to isolate the problem. It is indeed the esc and not the motor. When I switched motors on the bad esc, the new motor sounded with the weird whine. But when I switched esc's to a working one, the motors sounded normal.
I'll also add that when I throttle up with the bad esc, it feels as if the motor is resisting some, I'm sure this is the reason for all of the heat. (remember, I found out that all motors work)
I've been in the hobby for 8 years and always had electric cars, planes, trucks etc. This is the first time I've seen an esc act this way.
Discussion i really dont no which one to get? EJ1208 Nitro and Glow Power Cars 0 Apr 01, 2012 12:34 PM
Discussion I want one really bad ... logan5 Life, The Universe, and Politics 3 Mar 08, 2012 09:46 AM
Question MultiWii:Wires LIPO->Distribution->ESC getting REALLY hot jevermeister Multirotor Talk 16 Jan 14, 2012 05:52 AM
Discussion really really sad, I have a $150 dollar battery and one cell died sherlockshah Batteries and Chargers 19 Sep 27, 2011 04:07 AM
Discussion two brushless motors,two esc, one gets hot microdave Power Systems 5 Jan 04, 2006 11:43 PM
