Old Jun 22, 2011, 06:05 AM
Chophop is online now
Find More Posts by Chophop
I likes Electric Flies !
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
Motors that Whine Loudly
I have several motyors that make a loud whine. I replaced them with ones that are more quiet. They don't have to be top line motors to be reasonably quiet, but the better ones do seem to start at about $25, the $10 to $15 400 BLDC's are pretty sure to RRRRRRRRRRRRRrrrrrrrrRRRRRRRRR.
Any ideas on how to fix the whine ? I tried other low volume forums with no luck.
Chophop is online now Find More Posts by Chophop
Old Jun 22, 2011, 10:35 AM
simo10 is offline
Find More Posts by simo10
Planes from 1oz to 55lb's
simo10's Avatar
USA, FL, Orlando
Joined Aug 2004
The timing settings on your ESC play a bit part with noise, so try that first.
simo10 is offline Find More Posts by simo10
Old Jun 22, 2011, 11:51 AM
Chophop's Avatar
Joined Sep 2006
I have been through all tries with these motors. now connect a Scorpion, Hyperion, that level of motor and practically no noise. I know I can simply pay the price, but maybe a simple rewind, etc. may solve it ?
Old Jun 22, 2011, 12:45 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
It wouldn't surprise me that the cheaper motors sound noisier. It can also happen when the ESC arms. On some motors those 'beeping beeps' are enough to fetch the kids over looking for the ice cream seller.
A bit of a guess, but as it's the motor that actually makes the 'beeps', (it's the windings oscillating), then cheaper motors probably use poorer quality winding methods. And as the cheaper ESC probably have lower frequency switching, perhaps that can still be heard throughout most of its speed range.
Or it could be poor bearings, could be the airframe acting as a resonator, could be.........
eflightray is offline Find More Posts by eflightray
Old Jun 22, 2011, 02:20 PM
Chophop's Avatar
Joined Sep 2006
I did the testing on an Align BL-25G, a top quality ESC. All the cheaper motors make that RRRRR sound on any controller. Stick an Hyperion on and all I hear is a bit of prop noise and a very soft whirr that approxmates a nice Turboprop sound. Sounds VERY good.
Old Jun 22, 2011, 02:32 PM
C₄H₁₀ is offline
Find More Posts by C₄H₁₀
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
I know exactly what you're talking about. I've got a couple motors that make this fairly deafening, very obnoxious whine noise at certain points on the throttle range no matter which ESC I'm using. I'm thinking about testing with one of my Castle ESCs that have a lot of timing options to see if that affects it...
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Jun 22, 2011, 03:15 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Originally Posted by TP16 View Post
...fairly deafening, very obnoxious whine noise ...
In my house it's not the motor. It's my wife whenever I buy a new plane.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Jun 22, 2011, 03:50 PM
Chophop's Avatar
Joined Sep 2006
Get a set of ear plugs and that 50cc Yak-54. You had to say new plane, well that's on the way sometime as soon as I can spring for it. I'm sure she'll consider you macho.
Old Jun 22, 2011, 06:07 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
My 24 gram blue wonder motors make a nasty noise like a dentists' drill... but knock wood I've never killed one, and they do a great job in spite of the grating sound. Blue wonder is of course the generic term for the motor, the ones I have are chrome/nickel-plate finish.
rafe_b is offline Find More Posts by rafe_b
Old Jun 22, 2011, 10:12 PM
43851E is offline
Find More Posts by 43851E
43851E's Avatar
College Station, TX
Joined Jul 2009
some early types of ESCs have more of a "square" wave and do not taper off the trailing edge of the pulse going to the motor making it ring. Some like the sound with jets. The extra noise is actually waisted power> heat.
43851E is offline Find More Posts by 43851E
Old Jun 22, 2011, 10:24 PM
efflandt is offline
Find More Posts by efflandt
efflandt's Avatar
United States, IL, Elgin
Joined Mar 2011
Cheaper motors likely take short cuts in precision somewhere, type or tolerance of bearings, balance of the motor bell, materials, etc. So even if your prop is perfectly balanced, the motor may not be, shaft or prop adapter may not be as strong or straight, and/or bearings may be looser.
efflandt is offline Find More Posts by efflandt
Old Jun 22, 2011, 11:11 PM
C₄H₁₀ is offline
C₄H₁₀'s Avatar
Joined Aug 2009
This sound isn't a bearing issue, and it's not caused by mechanical imbalances. It sounds like some type of whistle or something; it's hard to describe unless you can be sitting in the room with the motor when it's running. If you heard it, you'd know what I mean.
ESC-related explanations seem most logical. I'm gonna go test a bunch of ESCs in a little while. On the board for testing:
Motor:
Suppo BL2217/6 1500Kv outrunner
Possible ESCs:
Jeti 30A (blue)
HobbyKing SuperSimple 25A
Castle Creations Phoenix 25 (two versions)
HobbyKing SuperSimple 50-65A heli
Suppo 30A
Flying Legends 20A
Art-Tech 18A
That's a pretty decent sampling of brands and quality, I think. I'll check back later with results.
Old Jun 23, 2011, 03:04 AM
Chophop's Avatar
Joined Sep 2006
The only gold can type of Supo I have is a pretty good motor and makes only a small bit of noise. A good choice to look for ESC caused noise.The sound I am refering to is the CD Rom sound. I think some people could have a CD Rom motor running while blindfolded and identify it every time.
I asked this question before and one person said the bell can is flimsy and vibrating. Not on a CD ROM, they are thick. I do have an Optima motor with a thin bell and the shrink wrap over the can trick did a small bit of help. Still no smooth whirrr like the Scorps, Hyperions, Himax etc.
I wonder if it could have something to do with the magnet and stator configuration ? Those motors do make the same sound as when powered but at a low volume when in a steep glide, throttle off, and the prop is wind powered.
Old Jun 23, 2011, 06:17 AM
flypaper 2 is online now
Find More Posts by flypaper 2
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
A buddy had a motor with a real loud whine to it. He changed the timing and it quieted right down.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jun 23, 2011, 08:15 AM
Ghost Plane is offline
Find More Posts by Ghost Plane
United States, NY, Angola
Joined Jul 2010
I have a couple of cheap alpha370 motors from nitroplanes that do this. They whine at about 1/2 throttle for me(which is where I fly most of the time). I had them on different esc's and both did it. I have a park400 that now runs on one of the esc that the one whining motor ran on and it's perfectly quite. No whining noise what so ever. All you hear is prop sounds.
Ghost Plane is offline Find More Posts by Ghost Plane
Discussion AXI 2826/12 Running Loudly-Help dorado Power Systems 0 Sep 16, 2010 12:19 PM
Discussion servo clicking loudly moevillarreal Fuel Plane Talk 7 Aug 18, 2008 12:52 PM
Discussion are brushless motors that much better then brushed motors? drew22to375 Beginner Training Area (Aircraft-Electric) 8 Oct 18, 2006 03:34 PM
Discussion Need a little Cheese with that Whine? aerogel Life, The Universe, and Politics 6 Apr 24, 2006 09:26 AM
