Old May 22, 2011, 06:12 PM
fast540 is offline
Find More Posts by fast540
Joined Aug 2010
Great Planes Super Sportster EP Rx-R
anyone seen or flown this new little guy yet? it looks interesting and i really enjoy the larger version.we r thinking about spec racing them
fast540 is offline Find More Posts by fast540
Old May 23, 2011, 02:00 PM
RCAV8T0R is offline
Find More Posts by RCAV8T0R
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
GPSS Rx-R Initial Review
Maiden flight for mine was yesterday in windy conditions here in So Cal. I flew it once as the wind was blowing steady around 12 - 15 mph and was gusting even harder at the field, especially when I wanted to land. What's worse it was a 90-degree cross wind to the runway. Not the ideal conditions for a first flight but I was anxious to get it in the air after prepping it earlier in the week. Got it down safely but it wasn't very smooth ending up in some tall weeds...
I'm a novice RC pilot but from my perspective the plane flies well. It's a balanced flier and the CG was spot on as called out in the manual. Very predictable and stable handling. Tracks well and carves turns without needing much up elevator input to keep the nose pointed in the direction you want to go. It's not very fast (yet) but it did handle the wind pretty well. Still it's a fairly small and light plane as it did get pushed around by the turbulent winds.
I flew mine stock except for using a 25C 1800 mAh battery and switching the non-equal length rudder and elevator servo arms. The rudder servo arm is longer than the elevator's and (to me) the elevator throw is not nearly enough. After bench testing it, it seemed the rudder had too much travel whereas the elevator did not, maybe barely 20 degrees of deflection. I merely swapped the servo arms and did an EPA on my Airtronics SD-6G radio to lengthen out the rudder travel to compensate for the switch.
This is my first Great Planes/Electrifly model and I have to say I'm very impressed with the quality of this GPSS Rx-R aircraft. I've had my share of RTF's and a couple of receiver-ready models that leave a lot to be desired but this foam flyer is different. Excellent fit and finish, lots of attention to detail, nice pre-applied decals, and I like the use of the plywood for the battery tray, mating surfaces and servo mounts. It has a stout landing gear and that's a big plus in my book. The only problem I had during assembly was that the spinner back plate hole was too small for the supplied prop adapter so I had to drill it out to make it fit.
After only one flight it's easy to tell this plane is begging for hop ups. Next, I'm going to try a larger prop. It comes with a 9x6SF and I've got a 10x7SF to try out. If it pulls too much current or if there's too much torque I might have to try another smaller prop. Or, I might drop in a larger motor and ESC. That's on the to do list anyway.
I've got a feeling the GPSS Rx-R is going to get quite a lot of air time in the very near future...
RCAV8T0R is offline Find More Posts by RCAV8T0R
Old May 24, 2011, 03:00 PM
fast540 is offline
Joined Aug 2010
awsome insight into this parkflyer thank you.there is five of us so far that are gonna maiden and pylon race these birds this weekend.ill report on how it goes later
Old May 25, 2011, 09:26 AM
RCAV8T0R is offline
RCAV8T0R's Avatar
Joined Apr 2011
Thanks fast540. I enjoy sharing the RC experience with other enthusiasts.
Sounds like it's going to be a great time. Lookin' forward to your report of how it all goes down, no pun intended...
Old May 30, 2011, 01:00 AM
fast540 is offline
Joined Aug 2010
we had the group maiden today.this the perfect plane for entry level spec racing
Old May 30, 2011, 09:17 AM
RCAV8T0R is offline
RCAV8T0R's Avatar
Joined Apr 2011
First Impressions?
I'm curious as to how you and the others set your GPSS Rx-R's up for the first flight. Did you fly 'em stock, or otherwise?
What did you think? Good flying entry-level sport plane that could use some performance enhancements to make it even more capable?
Old Jun 01, 2011, 05:36 PM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
Mine finally showed up today. Yeah!!!
Need to get an adaptor for the ESC to Deans plug, though, before i can finish her.
She sure went together easily.
Has anyone tried to fly this plane off grass with the stock wheels yet - they look like the might be OK - but not sure
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Jun 01, 2011, 08:49 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Well I had some bigger wheels so I just went ahead and put them on. Receiver is in, so I just need that adapter to be ready to go.
Weather is not looking real good for the next two days though.
Wolofe
Old Jun 01, 2011, 10:27 PM
RCAV8T0R is offline
RCAV8T0R's Avatar
Joined Apr 2011
ESC Connector Change
Depending on the grass height the stock wheels should work but not if it's too tall or bumpy.
Wolofe
I ditched the stock GP connector in favor of a Deans. I cut it off and soldered on a male Deans since I use these on all my Parkflyers and other planes that use 3S Lipos and under.
Old Jun 03, 2011, 02:59 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
New 40" Foam Super Sportster Rocks!
I've been flying about 3 months and this is my 6th plane.
I performed my first Real rolls today on my maiden flight.
Really like this plane. It's quite fast to me.
I too had to hand twist a drill bit throught the spinner backing plate to get it over the adapter shoulder.
Had to reset the linkages for both ele. and rud.
Running 2200 3s no problem. Soldered in XT60 ESC connector.
Suggested Cg is spot on.
Hand launching no trouble with gear off.
VERY concerned however about the ail. servos and linkages hanging down way too much. Half of each servo is sticking down out of the wing. No problem today with 2 landings. Just coasted in to land, no big deal.
Don't know what to do to get those honkers covered up???
None of my Composite covers will help this.
It's a quick and responsive plane and my new favorite.
Had a lot of fun.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Jun 03, 2011, 08:17 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Mine is ready to go.
I also ditched the stock connector in favor of Deans - all of my batteries are Deans
Grats on the successful Maiden IFly. Pretty exciting to get to start doing some aerobatics. This should be a good plane for you.
BUT - if you are flying off grass and belly landing you will rip those servos out or damage them before long. You might try a foam or balsa wedge glued to the wing just in front of the servos. or a plastic tail skid in front of the servos. Personally, I would go tail skid. You need to do something soon tho.
I fly off short grass too - but I just put 3" wheels on mine.
I am going to try 1300 mah 3s lipos - mostly because I have 6 of them and I use the bigger batteries in other planes - and I want to keep this one as light as possible. Maiden for me should be in the morning unless something unforseen comes up. Winds are supposd to be just under 10 mps.
Wolfe
Old Jun 04, 2011, 10:57 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Well I got to maiden this one today. Winds were about 10 mph and she was very tail heavy. I didn't even try to trim her - just brought her around with varying amounts of down elevator and put her back on the ground to make some adjustments. Was just happy to get her down in one piece - wasn't sure I was going to able to do that.
Second flight was much better. She is a pretty smooth flyer. Took it pretty easy, just some figure eights and a few loops, rolls and inverted passes at medium speeds. I don't ever really push an airplane too hard at first.
Looking forward to flying this one some more - she will probably be my new "GO TO" airplane until I get my skills back up.
The 1300 mah batteries worked fine once a made a couple adjustments and got the CG worked out.
Wolfe
Old Jun 05, 2011, 08:58 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Thanks Wolfe for the servo cover ideas.
Any idea what motor is in this plane?
Think I have a bearing noise. It's pretty bad.
It's not good just spinning slow by hand.
Just balanced the backing plate and prop but not out too much.
The spinner is not very centered though. It has a gap on one screw side but not the other so I can see some wiggle in it.
Watts seem to settle in around the 170 area. Started out at 189.
Old Jun 06, 2011, 11:28 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
I am guessing it is about a 400 sized motor. Anything betwwen 150 and 200 watts should fly this plane fine.
Take off that spinner if you can't get it to center properly, it will ruin any motor the way you said it is now.
Wolfe
Old Jun 08, 2011, 05:16 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
Motor uses an odd 3 leg mount that attaches to the rear shaft bearing and no luck at LHS.
Am contacting Great Planes support for availability at this time.
UPDATE: Great Planes is sending out a motor and spinner.
Happy with that :>)
Discussion SUPER SPORTSTER EP by GREAT PLANES (Guapoman2000) guapoman2000 Sport Planes 854 Mar 19, 2015 07:48 AM
Article Great Planes Super Sportster EP ARF Review wahrhaftig Electric Plane Talk 12 Sep 14, 2009 07:55 PM
Alert SUPER SPORTSTER EP by GREAT PLANES with Modified Power setup! (Guapoman2000) guapoman2000 Sport Planes 499 May 29, 2005 11:44 AM
Great Planes Super Sportster EP Arf mickydee Electric Plane Talk 11 Nov 15, 2004 05:27 PM
